ok.
same sketch as before except changed to Serial 1/2/USB.
exactly same cable setup as before - nothing done with that board between then and now.
As you can see i’m able to access ttyACM0 (usb port) and also ttyS4 (Serial1) perfectly fine in linux.
However, i’m now getting framing errors on Serial2 which is the 4 pin header.
