WPS is the easiest way to connect… and works well on the Xiao ESP32c3,
I’m using an ARRIS Router with a Hard & Soft WPS button press. AOK
THIS lightly tweeked PJG Example Code To Get ESP32c3 info from chip
 and to Connect WPS button AP and display RSSI, as well as do a BLE scan for devices.(WIP) concurrently
 or as close as possible.
This example code provides both Push Button method and Pin
based WPS entry to get your ESP connected to your WiFi router.
Hardware Requirements
ESP32 and a Router having WPS functionality
This code is under Public Domain License.
Author:
Pranav Cherukupalli <[email protected]>
#include "WiFi.h"
#include "esp_wps.h"
Change the definition of the WPS mode
from WPS_TYPE_PBC to WPS_TYPE_PIN in
the case that you are using pin type
WPS
#include <BLEDevice.h>
#include <BLEUtils.h>
#include <BLEScan.h>
#include <BLEAdvertisedDevice.h>
#define ESP_WPS_MODE      WPS_TYPE_PBC
#define ESP_MANUFACTURER  "SEEED"
#define ESP_MODEL_NUMBER  "ESP32C3"
#define ESP_MODEL_NAME    "Xiao ESP"
#define ESP_DEVICE_NAME   "ESP STATION"
uint32_t chipId = 0;
static esp_wps_config_t config;
int scanTime = 5; //In seconds
BLEScan* pBLEScan;
class MyAdvertisedDeviceCallbacks: public BLEAdvertisedDeviceCallbacks {
    void onResult(BLEAdvertisedDevice advertisedDevice) {
      Serial.printf("Advertised Device: %s \n", advertisedDevice.toString().c_str());
void setup(){
  Serial.begin(115200);
  Serial.println();
   for(int i=0; i<17; i=i+8) {
	  chipId |= ((ESP.getEfuseMac() >> (40 - i)) & 0xff) << i;
	Serial.printf("ESP32 Chip model = %s Rev %d\n", ESP.getChipModel(), ESP.getChipRevision());
	Serial.printf("This chip has %d cores\n", ESP.getChipCores());
  Serial.print("Chip ID: "); Serial.println(chipId);
	delay(2000);
  WiFi.onEvent(WiFiEvent);
  WiFi.mode(WIFI_MODE_STA);
  Serial.println("Starting WPS"); // GO press WPS button.
  wpsInitConfig();
  wpsStart();
  Serial.println("Scanning...");
 //delay(2000);
  while ( WiFi.status() != WL_CONNECTED) { //Wait for connection
   //Serial.println(WiFi.localIP());
   delay(20000);
   // print the received signal strength:
  long rssi = WiFi.RSSI();
  Serial.print("RSSI:");
  Serial.println(rssi);
void loop(){
   //Serial.println(WiFi.localIP ());
 delay (5000);
 //goBlue ();
void goBlue () {
BLEDevice::init("");
 pBLEScan = BLEDevice::getScan(); //create new scan
 pBLEScan->setAdvertisedDeviceCallbacks(new MyAdvertisedDeviceCallbacks());
 pBLEScan->setActiveScan(true); //active scan uses more power, but get results faster
 pBLEScan->setInterval(100);
 pBLEScan->setWindow(99);  // less or equal setInterval value
 BLEScanResults foundDevices = pBLEScan->start(scanTime, false);
 Serial.print("BLE-Devices found: ");
 Serial.println(foundDevices.getCount());
  Serial.println("BLE-Scan done!");
 pBLEScan->clearResults();   // delete results fromBLEScan buffer to release memory
void wpsInitConfig(){
  config.wps_type = ESP_WPS_MODE;
  strcpy(config.factory_info.manufacturer, ESP_MANUFACTURER);
  strcpy(config.factory_info.model_number, ESP_MODEL_NUMBER);
  strcpy(config.factory_info.model_name, ESP_MODEL_NAME);
  strcpy(config.factory_info.device_name, ESP_DEVICE_NAME);
void wpsStart(){
    if(esp_wifi_wps_enable(&config)){
    	Serial.println("WPS Enable Failed");
    } else if(esp_wifi_wps_start(0)){
    	Serial.println("WPS Start Failed");
void wpsStop(){
    if(esp_wifi_wps_disable()){
    	Serial.println("WPS Disable Failed");
String wpspin2string(uint8_t a[]){
  char wps_pin[9];
  for(int i=0;i<8;i++){
    wps_pin[i] = a[i];
  wps_pin[8] = '\0';
  return (String)wps_pin;
void WiFiEvent(WiFiEvent_t event, arduino_event_info_t info){
  switch(event){
    case ARDUINO_EVENT_WIFI_STA_START:
      Serial.println("Station Mode Started");
      break;
    case ARDUINO_EVENT_WIFI_STA_GOT_IP:
      Serial.println("Connected to :" + String(WiFi.SSID()));
      Serial.print("Got IP: ");
      break;
    case ARDUINO_EVENT_WIFI_STA_DISCONNECTED:
      Serial.println("Disconnected from station, attempting reconnection");
      WiFi.reconnect();
      break;
    case ARDUINO_EVENT_WPS_ER_SUCCESS:
      Serial.println("WPS Successfull, stopping WPS and connecting to: " + String(WiFi.SSID()));
      wpsStop();
      delay(10);
      WiFi.begin();
      break;
    case ARDUINO_EVENT_WPS_ER_FAILED:
      Serial.println("WPS Failed, retrying");
      wpsStop();
      wpsStart();
      break;
    case ARDUINO_EVENT_WPS_ER_TIMEOUT:
      Serial.println("WPS Timedout, retrying");
      wpsStop();
      wpsStart();
      break;
    case ARDUINO_EVENT_WPS_ER_PIN:
      Serial.println("WPS_PIN = " + wpspin2string(info.wps_er_pin.pin_code));
      break;
    default:
      break;
Output on Ser.Mon.
ESP32 Chip model = ESP32-C3 Rev 3
This chip has 1 cores
Chip ID: 4196588
Starting WPS
Scanning...
RSSI:0
sm BSSid: 00:00:00:00:00:00 scan BSSID d4:04:cd:ff:0e:54
RSSI:-53
WPS Successfull, stopping WPS and connecting to: GlassSurf-2.4
E (45554) wifi:sta is connecting, return error
RSSI:-54
RSSI:-54
RSSI:-54
RSSI:-54
Connected to :GlassSurf-2.4
Got IP: 192.168.1.189
RSSI:-54
Works well holds connection NO Issues.
on to BLE’ Scan. (goBlue)
GL :-p
