Jetson Xavier NX with A203 v2 carrier board - cannot detect SD card
Hello all,
We are using the carrier board version A203 (V2) with Jetson Xavier NX. We flashed the JetPack 5.0.2 with the SDK manager but we later found it was not able to detect the SD card.
Then we tried JetPack 4.6 according to the wiki page but we met following errors: https://forum.seeedstudio.com/t/error-flashing-xavier-nx-on-a-a203v2-carrier-board/264707
So is there a tutorial showing how to use JetPack 5.0.2 with SD card?
Thanks in advance!
I found the solution. Since our Jetson is the 16GB version, just rename the driver (from p3668-0001 to p3668-0003) to match the board.
This is awesome, I’m curious how you found it.
Also maybe by any chance you managed to set up an SSD? =)
