How to run grove 0,96" OLED Display with hello world example on Beagle Bone Green wireless?
Moderators: lily.li, salmanfarisvp, violet, seth.welday
facemaker-lp
Post by facemaker-lp » Wed Jul 11, 2018 8:45 pm
I know the question is a bit dumb but I am new and I need help. So I have a problem: Everytime when I run the hello world example code from the
seeed wiki, for my Grove OLED screen, I see this message:
File "/var/lib/cloud9/Grove/OLED.py", line 2, in <module>
import smbus2 as smbus
ImportError: No module named smbus2
I must install the smbus2 library (sudo pip install smbus2), but I don't know where to write it. I know, it sounds stupid, but there is no tutorial on YouTube or on google. Please help me to learn the basics.
Thank you,
Grooxy
hong.jiang
Staff
Staff
Re: How to run grove 0,96" OLED Display with hello world example on Beagle Bone Green wireless?
Post by hong.jiang » Thu Jul 12, 2018 3:29 pm
Hi Grooxy
please run below commands
1. sudo apt update
2. sudo apt install python3-pip
3. sudo pip3 install smbus2
4. copy the codes to OLED.py and then run below command
5. sudo python3 OLED.py
Seeed techsupport team
Bill
facemaker-lp
Post by facemaker-lp » Sat Jul 14, 2018 7:23 am
First, thank you for the help!
But I have a little problem: so I wrote the commands: sudo apt update then sudo apt install python3-pip but when I wrote sudo pip3 install smbus2 cloud9 showed me this:
Code: Select all
 Collecting smbus2
Exception:
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 138, in _new_conn
    (self.host, self.port), self.timeout, **extra_kw)
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/connection.py", line 75, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/lib/python3.5/socket.py", line 733, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:Traceback (most recent call last):
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 594, in urlopen
    chunked=chunked)
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 350, in _make_request
    self._validate_conn(conn)
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 837, in _validate_conn
    conn.connect()
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 281, in connect
    conn = self._new_conn()
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py", line 147, in _new_conn
    self, "Failed to establish a new connection: %s" % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb5980750>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
  File "/usr/lib/python3/dist-packages/pip/basecommand.py", line 215, in main
    status = self.run(options, args)
  File "/usr/lib/python3/dist-packages/pip/commands/install.py", line 353, in run
    wb.build(autobuilding=True)
  File "/usr/lib/python3/dist-packages/pip/wheel.py", line 749, in build
    self.requirement_set.prepare_files(self.finder)
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 380, in prepare_files
    ignore_dependencies=self.ignore_dependencies))
  File "/usr/lib/python3/dist-packages/pip/req/req_set.py", line 554, in _prepare_file
    require_hashes
  File "/usr/lib/python3/dist-packages/pip/req/req_install.py", line 278, in populate_link
    self.link = finder.find_requirement(self, upgrade)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 465, in find_requirement
    all_candidates = self.find_all_candidates(req.name)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 423, in find_all_candidates
    for page in self._get_pages(url_locations, project_name):
  File "/usr/lib/python3/dist-packages/pip/index.py", line 568, in _get_pages
    page = self._get_page(location)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 683, in _get_page
    return HTMLPage.get_page(link, session=self.session)
  File "/usr/lib/python3/dist-packages/pip/index.py", line 792, in get_page
    "Cache-Control": "max-age=600",
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 501, in get
    return self.request('GET', url, **kwargs)
  File "/usr/lib/python3/dist-packages/pip/download.py", line 386, in request
    return super(PipSession, self).request(method, url, *args, **kwargs)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 488, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py", line 609, in send
    r = adapter.send(request, **kwargs)
  File "/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py", line 47, in send
    resp = super(CacheControlAdapter, self).send(request, **kw)
  File "/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py", line 423, in send
    timeout=timeout
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py", line 643, in urlopen
    _stacktrace=sys.exc_info()[2])
  File "/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py", line 315, in increment
    total -= 1
TypeError: unsupported operand type(s) for -=: 'Retry' and 'int'
Do you know what I should do, I hope somebody can help!
hong.jiang
Staff
Staff
Post by hong.jiang » Thu Jul 19, 2018 8:53 am
Hi there, please retry and see if it can help. thanks.
Bill
