I know the question is a bit dumb but I am new and I need help. So I have a problem: Everytime when I run the hello world example code from the
seeed wiki, for my Grove OLED screen, I see this message:
File “/var/lib/cloud9/Grove/OLED.py”, line 2, in
import smbus2 as smbus
ImportError: No module named smbus2
I must install the smbus2 library (sudo pip install smbus2), but I don’t know where to write it. I know, it sounds stupid, but there is no tutorial on YouTube or on google. Please help me to learn the basics.
Thank you,
Grooxy
Hi Grooxy
please run below commands
- sudo apt update
- sudo apt install python3-pip
- sudo pip3 install smbus2
- copy the codes to OLED.py and then run below command
- sudo python3 OLED.py
Seeed techsupport team
Bill
First, thank you for the help!
But I have a little problem: so I wrote the commands: sudo apt update then sudo apt install python3-pip but when I wrote sudo pip3 install smbus2 cloud9 showed me this:
[code] Collecting smbus2
Exception:
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py”, line 138, in _new_conn
(self.host, self.port), self.timeout, **extra_kw)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/connection.py”, line 75, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/lib/python3.5/socket.py”, line 733, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Temporary failure in name resolution
During handling of the above exception, another exception occurred:Traceback (most recent call last):
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 594, in urlopen
chunked=chunked)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 350, in _make_request
self._validate_conn(conn)
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 837, in _validate_conn
conn.connect()
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py”, line 281, in connect
conn = self._new_conn()
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connection.py”, line 147, in _new_conn
self, “Failed to establish a new connection: %s” % e)
requests.packages.urllib3.exceptions.NewConnectionError: <requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0xb5980750>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution
File “/usr/lib/python3/dist-packages/pip/basecommand.py”, line 215, in main
status = self.run(options, args)
File “/usr/lib/python3/dist-packages/pip/commands/install.py”, line 353, in run
wb.build(autobuilding=True)
File “/usr/lib/python3/dist-packages/pip/wheel.py”, line 749, in build
self.requirement_set.prepare_files(self.finder)
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 380, in prepare_files
ignore_dependencies=self.ignore_dependencies))
File “/usr/lib/python3/dist-packages/pip/req/req_set.py”, line 554, in _prepare_file
require_hashes
File “/usr/lib/python3/dist-packages/pip/req/req_install.py”, line 278, in populate_link
self.link = finder.find_requirement(self, upgrade)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 465, in find_requirement
all_candidates = self.find_all_candidates(req.name)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 423, in find_all_candidates
for page in self._get_pages(url_locations, project_name):
File “/usr/lib/python3/dist-packages/pip/index.py”, line 568, in _get_pages
page = self._get_page(location)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 683, in _get_page
return HTMLPage.get_page(link, session=self.session)
File “/usr/lib/python3/dist-packages/pip/index.py”, line 792, in get_page
“Cache-Control”: “max-age=600”,
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 501, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/lib/python3/dist-packages/pip/download.py”, line 386, in request
return super(PipSession, self).request(method, url, *args, **kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 488, in request
resp = self.send(prep, **send_kwargs)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/sessions.py”, line 609, in send
r = adapter.send(request, **kwargs)
File “/usr/share/python-wheels/CacheControl-0.11.7-py2.py3-none-any.whl/cachecontrol/adapter.py”, line 47, in send
resp = super(CacheControlAdapter, self).send(request, **kw)
File “/usr/share/python-wheels/requests-2.12.4-py2.py3-none-any.whl/requests/adapters.py”, line 423, in send
timeout=timeout
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/connectionpool.py”, line 643, in urlopen
_stacktrace=sys.exc_info()[2])
File “/usr/share/python-wheels/urllib3-1.19.1-py2.py3-none-any.whl/urllib3/util/retry.py”, line 315, in increment
total -= 1
TypeError: unsupported operand type(s) for -=: ‘Retry’ and ‘int’[/code]
Do you know what I should do, I hope somebody can help!
Hi there, please retry and see if it can help. thanks.
Bill
