Hi there~
- If you burn the below code to shield bot, both of the motors shall rotate.
<LINK_TEXT text=“http://wiki.seeedstudio.com/Shield_Bot_ … ng-started”>http://wiki.seeedstudio.com/Shield_Bot_V1.2/#getting-started</LINK_TEXT>
- If it does not rotate, the shield bot may be bad from hardware point of view. The motor is connected with L298 and then controlled by arduino through IN1/IN2/IN3/IN4 and ENA/ENB. We suspect the L298 is dead. thanks.
