HI,
i just try to connect ReSpeaker Mic Array v2.0 on Rasperry Pi 3 Model B with Windows IoT Core vers.17661 and I see that speaker works well but
I've problem with microphone.
when I use this sample : https://github.com/Microsoft/Windows-io ... Translator , Cortana speech recognition doesn't work. The same example works on Windows 10 with the same respeaker.
Anyone out there did similar test? If yes, what's Windows IoT Core version? Did u install a driver?
ReSpeaker Mic Array v2.0 on Rasperry Pi 3 Model B with Windows IOT core
Moderators: violet, seth.welday
- Staff
Re: ReSpeaker Mic Array v2.0 on Rasperry Pi 3 Model B with Windows IOT core
We did a test with https://github.com/Microsoft/Windows-io ... ure-object and it can record the audio correctly, it does not need any driver. we just use the oct release. https://docs.microsoft.com/en-us/window ... /downloads thanks.
- Pre-kindergarten
Are you sure_. Could it be that you were using the camera mic instead of the mic array?. I need to solve this quicly. Would you share the code you used?
There should be a driver for this.
Thanks a lot!
Thanks a lot!
- Pre-kindergarten
Any nes on this?. I`m really interested in this and perhaps there are more people trying to do this.
Thanks.
Thanks.
- Pre-kindergarten
Any news?. I'm thining in buying a couple of dozens for windows 10 iot, but I don't have any news from you. Would you please HELP me!!.
Thanks.
Thanks.
