I can not use micro sd card
orion96
Post by orion96 » Mon Jul 19, 2010 1:15 am
Hello.
I bought DSO Nano some days ago.
I have Sandisk 2GB micro SD card.
I think this is the same memory with http://www.seeedstudio.com/depot/sandis ... th=104_110 .
I formatted my memory with FAT file system on my PC(Windows XP SP3).
And I copy all files with FILEXXX.DAT and CONFIG.DAT following the FAQ on this web board.
Buw when I insert this card into my DSO Nano.
I can't save waveforms.
And I wonder my DSO Nano works well or not.
When I try to select FS, the cursor is skip from x1 to Fo.
Does it works well?
Help me... ^^
User avatar
esp
Elementary-3
Elementary-3
Re: I can not use micro sd card
Post by esp » Mon Jul 19, 2010 12:03 pm
If you can't use menu FS and FL, means the card is not even recognized by DSO. Would it be possible to try another card?
Also, you could try power off and on after inserting the TF card to see if it works. (I personally have this experrience sometimes.)
dnordenberg
Kindergarten
Kindergarten
Post by dnordenberg » Wed Jul 21, 2010 5:02 am
Wasn't there a 1gb limit???
User avatar
esp
Elementary-3
Elementary-3
Post by esp » Wed Jul 21, 2010 8:43 am
The limit should be 2GB. Thanks!
tkleong1437
Post by tkleong1437 » Sun Jul 25, 2010 5:04 pm
same problem as my except the FS/FL menu valid on screen except the "Micro SD Err" message while save/load. Any suggestion ? Thanks.
MicroSD : Kingston Model : SD/2GB
Firmware
App : 2.31
LIB : 2.21
User avatar
esp
Elementary-3
Elementary-3
Post by esp » Mon Jul 26, 2010 8:45 am
If FL and FS are valid, then it is mostly the file setup problem. Please try follow the FAQ on the SD card preparation.
http://www.seeedstudio.com/forum/viewto ... f=12&t=534
tkleong1437
Post by tkleong1437 » Mon Jul 26, 2010 9:16 am
follow as instruction step, problem remain MicroSD Err on load/save.
User avatar
esp
Elementary-3
Elementary-3
Post by esp » Tue Jul 27, 2010 9:19 am
It should be the compatibility issue, could you try another brand? Sorry for the inconvenience but we can't test every card.
We have a Sandisk one proven working and in stock. Thanks!
tkleong1437
Post by tkleong1437 » Sat Jul 31, 2010 5:50 pm
problem fixed, incompatible on kingstone 2GB, get new Sandisk 2GB tested working fine. Thanks a lot.
