LoRa Radio
daniel.wright
LoRa Radio
Post by daniel.wright » Tue May 21, 2019 1:47 am
Hi all,
We have bought the LoRa 868Mhz radios.
We have successfully got the point to point client/server examples working using the provided libraries on the Wiki.
However, we are now trying to get the LMIC library working (also linked on the bottom of the Wiki) to connect to TTN (The Things Network) and not having much luck. The LMIC library appears to be written as if the chip is directly connected to the Arduino pins rather than via the Grove shield. I can see the Grove library uses a SoftwareSerial connection of pins 5 and 6 and the RadioHead library. How can I get the LMIC library working? Am I missing something?
Thanks!
