Seeeduino LoRaWAN External Antenna
carlan
Post by carlan » Tue Jun 11, 2019 4:04 am
Does the external uFL antenna port work for 915 MHz and if so is there something that must be done to enable the uFL port? I removed the wire antenna and connected an antenna to the uFL port and there was no signal.
Thank you
bill.yu
Junior-7
Junior-7
Re: Seeeduino LoRaWAN External Antenna
Post by bill.yu » Fri Jun 14, 2019 3:37 pm
No hardware change needed. What kinds of antenna do you use? It supports 868Mhz and 915MHz. We designed the seeeduino lorawan node to collect data as below. thanks.
