New Product Ideas: Grove Kit for Maixduino, let us know what you expect to see!
If you have a new product idea, let us know here!
Moderators: lily.li, violet, jeremy882, lakshanthad, elaine.wu
User avatar
violet
Staff
Staff
Post by violet » Thu May 30, 2019 8:26 pm
Excited to release Maixduino last week, a RISC-V 64 development board for AI + IoT applications, and we know you like it!
We are planning on a Grove Kit for Maixduino, including Maixduino board, OV2640 camera module, 2.4-inch TFT display, Grove base shield and 9 most expected Groves from your feedback.
    Please reply with at least 9 of your favorite or needed Grove modules you expect for Maixduino Kit! You can write down more sensors we do not have on the list. The 9 grove modules will be selected by you through votes. In total the Kit will be much cheaper than you buy Maixduino and other Grove modules separately.
      Everyone who entered the survey will get $1 coupon for any of Sipeed products.
        If we finally adopt your advice into mass production, we will send you another $5 coupon for the kit!
          Look forward to your prototypes! Everyone who will buy the kit and send us your prototype with the future Maixduino Kit, we will exclusively send you $10 coupon for order over $100
          Grove - 3-Axis Digital Accelerometer(±1.5g)
          Grove - Air quality sensor v1.3
          Grove - Collision Sensor
          Grove - Dust Sensor
          Grove - Infrared Reflective Sensor v1.2
          Grove - Light Sensor
          Grove - Moisture Sensor
          Grove - PIR Motion Sensor
          Grove - Rotary Angle Sensor
          Grove - Sound Sensor
          Grove - Temperature Sensor
          Grove - Temperature, Humidity, Pressure and Gas Sensor (BME680)
          Grove - Time of Flight Distance Sensor(VL53L0X)
          Grove - Touch Sensor
          Grove - Ultrasonic Ranger
          Grove - Water Sensor
          PIR Motion Sensor - Large Lens version
          Grove - Red LED Button
          Grove - Chainable RGB LED v2.0
          Grove - RGB LED Stick (10 - WS2813 Mini)
          Grove LED Bar v2.0
          Grove - 4-Digit Display
          Grove - Button
          Grove - Buzzer
          Grove - I2C Motor Driver
          Grove - LCD RGB Backlight
          Grove - Servo
          Grove - Smart Relay
          Mini Servo
          Grove - 125KHz RFID Reader
          Grove - BLE (dual model)
          Grove - MP3 v2.0
          Grove - NFC
          Grove - I2C Hub
          Years may wrinkle the skin, but to give up enthusiasm wrinkles the soul.---Youth
          baqwas
          Re: New Product Ideas: Grove Kit for Maixduino, let us know what you expect to see!
          Post by baqwas » Sat Jun 22, 2019 7:15 am
          Hello Violet,
          I am just starting out on testing the MAiXDUiNO. Don't see any issues with the Grove sensors once I get the display connected. Is there a diagram (or some documentation on how to connect the ribbon between the display and the Maixduino? Logically it appears a straightforward connection but I want to be sure that I have the correct edge of the ribbon to the matching edge of the pin on the Maixduino.
          Also, a note for future revision. It would be nice to have some mount for the camera (instead of letting it float - current appearance). The equivalent of the PiXY mount comes to mind. Also, please understand that we would like to use the stereo camera board (if possible) and suitable mounting for this board is desirable.
          I am using the Sunfounder RAB baseplate board to host the Maixduino, display and breadboard. The Maixduino and breadboard are easily fixed to the baseplat but the display is held in place with adhesive Velcro strips. it does the job for now but perhaps some Grove baseplate (I am not good in 3D modeling/printing) should be considered in the future by the community because the Maixduino seems to have potential to be better (and cheaper) than Google AIY Vision 1.1 kit.
          Kind regards.
          User avatar
          andre.ml.curvello
          Contact:
          Post by andre.ml.curvello » Tue Jul 09, 2019 7:56 am
          Hi Violet!
          Excellent idea.
          Here are my suggestions:
          Grove - I2C Hub
          Grove - Speaker
          Grove - Temperature & Humidity Sensor Pro
          Grove - Light&Gesture&Color&Proximity Sensor
          Grove - 12-Channel Capacitive Touch Keypad
          Grove - Relay
          Best regards,
          André Curvello
