New Product Ideas: Grove Kit for Maixduino, let us know what you expect to see!
Excited to release Maixduino last week, a RISC-V 64 development board for AI + IoT applications, and we know you like it!
We are planning on a Grove Kit for Maixduino, including Maixduino board, OV2640 camera module, 2.4-inch TFT display, Grove base shield and 9 most expected Groves from your feedback.
[list][/list]Please reply with at least 9 of your favorite or needed Grove modules you expect for Maixduino Kit! You can write down more sensors we do not have on the list. The 9 grove modules will be selected by you through votes. In total the Kit will be much cheaper than you buy Maixduino and other Grove modules separately.
[list][/list]Everyone who entered the survey will get $1 coupon for any of Sipeed products.
[list][/list]If we finally adopt your advice into mass production, we will send you another $5 coupon for the kit!
[list][/list]Look forward to your prototypes! Everyone who will buy the kit and send us your prototype with the future Maixduino Kit, we will exclusively send you $10 coupon for order over $100
Grove - 3-Axis Digital Accelerometer(±1.5g)
Grove - Air quality sensor v1.3
Grove - Collision Sensor
Grove - Dust Sensor
Grove - Infrared Reflective Sensor v1.2
Grove - Light Sensor
Grove - Moisture Sensor
Grove - PIR Motion Sensor
Grove - Rotary Angle Sensor
Grove - Sound Sensor
Grove - Temperature Sensor
Grove - Temperature, Humidity, Pressure and Gas Sensor (BME680)
Grove - Time of Flight Distance Sensor(VL53L0X)
Grove - Touch Sensor
Grove - Ultrasonic Ranger
Grove - Water Sensor
PIR Motion Sensor - Large Lens version
Grove - Red LED Button
Grove - Chainable RGB LED v2.0
Grove - RGB LED Stick (10 - WS2813 Mini)
Grove LED Bar v2.0
Grove - 4-Digit Display
Grove - Button
Grove - Buzzer
Grove - I2C Motor Driver
Grove - LCD RGB Backlight
Grove - Servo
Grove - Smart Relay
Mini Servo
Grove - 125KHz RFID Reader
Grove - BLE (dual model)
Grove - MP3 v2.0
Grove - NFC
Grove - I2C Hub
Hello Violet,
I am just starting out on testing the MAiXDUiNO. Don’t see any issues with the Grove sensors once I get the display connected. Is there a diagram (or some documentation on how to connect the ribbon between the display and the Maixduino? Logically it appears a straightforward connection but I want to be sure that I have the correct edge of the ribbon to the matching edge of the pin on the Maixduino.
Also, a note for future revision. It would be nice to have some mount for the camera (instead of letting it float - current appearance). The equivalent of the PiXY mount comes to mind. Also, please understand that we would like to use the stereo camera board (if possible) and suitable mounting for this board is desirable.
I am using the Sunfounder RAB baseplate board to host the Maixduino, display and breadboard. The Maixduino and breadboard are easily fixed to the baseplat but the display is held in place with adhesive Velcro strips. it does the job for now but perhaps some Grove baseplate (I am not good in 3D modeling/printing) should be considered in the future by the community because the Maixduino seems to have potential to be better (and cheaper) than Google AIY Vision 1.1 kit.
Kind regards.
Hi Violet!
Excellent idea.
Here are my suggestions:
Grove - I2C Hub
Grove - Speaker
Grove - Temperature & Humidity Sensor Pro
Grove - Light&Gesture&Color&Proximity Sensor
Grove - 12-Channel Capacitive Touch Keypad
Grove - Relay
Best regards,
André Curvello
Good idea? Has any progress been established since then?
