Hello guys,
I’d like to use a solar panel with the Xiao esp32 and still use the internal charger for the 18650 battery.
Would it work if I just attach the panel to the 5v pin with a diode so current just flows from the panel to the 5v pin not the other way?
Would it charge the battery if the sun delivers enough power ? Should it reset if the supply changes from 5v to battery if the solar panel stops delivering enough?
Cheers Michael
