Hi , is anybody know the official planing to fix the problem ??
Hi, is anybody know solution(s)?  thanks for your suggestions.
If currently do not support connect to hidden wifi network, then Wio Terminal is not suitable for my target project.
I do suffering from trouble shooting this issue recently !
thanks!
There is an instruction about Wio Terminal Wi-Fi advanced usage. Advanced Wi-Fi Usage - Seeed Wiki. Perhaps you can use it to try to build the hidden wifi support firmware.
Do you meant currently there has no official library support for Wio Terminal to connect to a hidden network? I try use Wifi manager, but after studies on its dependent head files/ cpp files, I m sure that I m not able to make it works at precent knowledge and skills…
