编译Wio终端初始固件(复古游戏)提示exit status 1 为开发板 Seeeduino Wio Terminal 编译时出错。如何解决?谢谢
麻烦提供更多的编译信息供我们分析。
“C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++” -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“jumper.ino”""" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/Core/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/DSP/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\variants\wio_terminal” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire” “C:\Users\JIAWEI~1\AppData\Local\Temp\arduino_build_963902\sketch\jumper.ino.cpp” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
“C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++” -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“jumper.ino”""" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/Core/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/DSP/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\variants\wio_terminal” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire” “C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SD\Seeed_SD.cpp” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
“C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++” -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“jumper.ino”""" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/Core/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/DSP/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\variants\wio_terminal” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire” “C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SD\Seeed_sdcard_hal.cpp” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
“C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++” -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“jumper.ino”""" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/Core/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/DSP/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\variants\wio_terminal” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire” “C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SD\sd_diskio_crc.c” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
“C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++” -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“jumper.ino”""" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10813 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed Studio”” “-DUSB_PRODUCT=“Seeed Wio Terminal”” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src” -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/Core/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.4.0/CMSIS/DSP/Include/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\cores\arduino” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\variants\wio_terminal” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master” “-IC:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master” “-IC:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire” “C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SFUD\Seeed_SFUD.cpp” -o nul -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for sfud.h: []
ResolveLibrary(sfud.h)
-> candidates: []
In file included from C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SFUD\Seeed_SFUD.cpp:8:0:
C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master\src\SFUD\Seeed_SFUD.h:18:10: fatal error: sfud.h: No such file or directory
#include <sfud.h>
compilation terminated.
“Adafruit_ZeroDMA.h” 对应多个库
已使用: C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA
未使用:C:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_Zero_DMA_Library
“TFT_eSPI.h” 对应多个库
已使用: C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master
未使用:C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Seeed_Arduino_LCD
使用 1.0 版本的库 Seeed_Arduino_FS-master 在文件夹: C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_FS-master
使用 1.0 版本的库 SPI 在文件夹: C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\SPI
使用 1.0.4 版本的库 Adafruit_ZeroDMA 在文件夹: C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Adafruit_ZeroDMA
使用 1.6.0 版本的库 Seeed_Arduino_LCD-master 在文件夹: C:\Users\jiaweitao\Documents\Arduino\libraries\Seeed_Arduino_LCD-master
使用 2.2.1 版本的库 Adafruit_ZeroTimer-master 在文件夹: C:\Users\jiaweitao\Documents\Arduino\libraries\Adafruit_ZeroTimer-master
使用 1.0 版本的库 Wire 在文件夹: C:\Users\jiaweitao\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.7.9\libraries\Wire
exit status 1
#include <sfud.h>
sfud 库文件有问题
那应该怎么处理呢?谢谢。![]()
Please add this library
谢谢 问题已解决
