Hello, I have two Grove Vision AI V2 modules, both flashed with the same person detection model from SenseCraft AI. However, I noticed that the two modules display images at different resolutions. The first module shows high-resolution images but with a low FPS, while the second module displays low-resolution images but with a higher FPS.
I’m not sure what’s causing this issue. Is there anything I can adjust to fix it? Could it be due to different firmware versions or variations in how data is being retrieved?
While writing this message, I reconnected the first module to SenseCraft, and now its image resolution and FPS match the second module’s settings. However, I would like to restore the high resolution that the first module originally had.
Please help me with this
