At a high level, I need the speaker to repeat what is said into a microphone. They need to be near each other. The obvious issue is the feedback / echo.
As I understand it - the solution is echo cancellation or Acoustic Echo Cancellation (AEC).
My hardware setup is:
- Raspberry Pi
- Justboom HAT - for speaker output - https://shop.justboom.co/collections/raspberry-pi-audio-boards/products/justboom-amp-hat
- USB audio dongle - for microphone input - https://www.jaycar.com.au/usb2-0-to-3-5mm-audio-converter/p/XC4953
I then done the following to setup things:
sudo apt-get -y install libasound2-dev libspeexdsp-dev
git clone https://github.com/voice-engine/ec.git
cd ec
make
cd ~
wget -c https://raw.githubusercontent.com/voice-engine/ec/master/asound.conf
mv asound ~/.asoundrc
Then I run the ec stuff:
./ec -i plughw:1,0 -o plughw:0
And finally connect the mic to the speaker via:
arecord -f dat - | aplay -
However I still hear an echo. It seems a little better than when I run the above without “ec”, but there is still an echo.
Any thoughts how to resolve this?
For your info. Here is the device lists:
pi@raspberrypi:~ $ arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
default
eci
eco
sysdefault:CARD=Audio
USB Audio, USB Audio
Default Audio Device
front:CARD=Audio,DEV=0
Front speakers
surround21:CARD=Audio,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Audio,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Audio,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Audio,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Audio,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Audio,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
iec958:CARD=Audio,DEV=0
IEC958 (S/PDIF) Digital Audio Output
dmix:CARD=Audio,DEV=0
Direct sample mixing device
dsnoop:CARD=Audio,DEV=0
Direct sample snooping device
hw:CARD=Audio,DEV=0
Direct hardware device without any conversions
plughw:CARD=Audio,DEV=0
Hardware device with all software conversions
pi@raspberrypi:~ $ aplay -L
null
default
eci
eco
sysdefault:CARD=sndrpijustboomd
snd_rpi_justboom_dac, JustBoom DAC HiFi pcm512x-hifi-0
dmix:CARD=sndrpijustboomd,DEV=0
dsnoop:CARD=sndrpijustboomd,DEV=0
hw:CARD=sndrpijustboomd,DEV=0
plughw:CARD=sndrpijustboomd,DEV=0
Front speakers
hw:CARD=Audio,DEV=0
