Hello
I’m trying to implement the Vision AI Module in python for the Raspberry Pi with GrovePi Plus.
I just rewrote almost one to one the given cpp file from GitHub /limengdu/Seeed-Grove-Vision-AI-Moudle.
In the end, I want to detect humans like shown on the wiki.
The problems I’m facing are the following:
- I don’t know which Index People Detected Model has. (MODEL_PRE_INDEX_1 or MODEL_EXT_INDEX_1?)
- When I use MODEL_PRE_INDEX_1 I stuck at “Invoke failed”. All other models give me an error in i2c.
Thanks for helping me in advance!
My code:
import smbus2 as smbus
import time
#features
FEATURE_SYSTEM = 0x80
FEATURE_ALGO = 0xA0
#commands
CMD_SYS_READ_STATE = 0x03
CMD_SYS_STATE_LENGTH = 0x01
CMD_SYS_RESET = 0x20
CMD_ALGO_INOVKE = 0xA0
CMD_ALGO_READ_RET_LEN = 0xA1
CMD_ALGO_READ_RET_LEN_LENGTH = 0x02
CMD_ALGO_WRITE_ALGO = 0x01
CMD_ALGO_WRITE_MODEL = 0x11
CMD_ALGO_WRITE_CONFIDENCE = 0x41
CMD_ALGO_CONFIG_SAVE = 0xEE
CMD_STATE_IDLE = 0x00
CMD_STATE_RUNNING = 0x01
CMD_STATE_ERROR = 0x02
ALGO_OBJECT_DETECTION = 0
ALGO_OBJECT_COUNT = 1
ALGO_IMAGE_CLASSIFICATION = 2
MODEL_PRE_INDEX_1 = 0x00
MODEL_PRE_INDEX_2 = 0x01
MODEL_PRE_INDEX_3 = 0x02
MODEL_PRE_INDEX_4 = 0x03
MODEL_EXT_INDEX_1 = 0x10
MODEL_EXT_INDEX_2 = 0x11
MODEL_EXT_INDEX_3 = 0x12
MODEL_EXT_INDEX_4 = 0x13
FOUR_BYTES = 0x04
CMD_SYS_READ_ID = 0x02
CMD_SYS_ID_LENGTH = 2
CMD_SYS_READ_VERSION = 0x01
CMD_SYS_VERSION_LENGTH = 2
CMD_ALGO_READ_ALGO = 0x00
CMD_ALGO_ALGO_LENGTH = 0x01
CMD_ALGO_READ_MODEL = 0x10
CMD_ALGO_MODEL_LENGTH = 0x01
CMD_ALGO_READ_CONFIDENCE = 0x40
CMD_ALGO_CONFIDENCE_LENGTH = 0x01
GROVE_AI_CAMERA_ID = 0x0100
class VisionAI(object):
def __init__(self, bus=1, address=0x62):
self.bus = smbus.SMBus(bus)
self.address = address
self.algo_confidence = 50
def read_data(self, data, num_of_bytes):
time.sleep(0.005)
write = smbus.i2c_msg.write(self.address, data)
self.bus.i2c_rdwr(write)
time.sleep(0.005)
read = smbus.i2c_msg.read(self.address, num_of_bytes)
self.bus.i2c_rdwr(read)
if (num_of_bytes == 1):
return list(read)[0]
return list(read)
def read_data_big_endian(self, data, num_of_bytes):
time.sleep(0.005)
time.sleep(0.005)
return sum(list(read)[-(i+1)]<<(8*i) for i, _ in enumerate(read)) # buf[0]<<8*2 | buf[1]<<8*1 | buf[2]
def write_data(self, data):
time.sleep(0.005)
def get_result_len(self):
return self.read_data([FEATURE_ALGO,CMD_ALGO_READ_RET_LEN],CMD_ALGO_READ_RET_LEN_LENGTH)
def state(self):
return self.read_data([FEATURE_SYSTEM,CMD_SYS_READ_STATE],CMD_SYS_STATE_LENGTH)
def config_save(self):
self.write_data([FEATURE_ALGO,CMD_ALGO_CONFIG_SAVE])
while(1):
ret = self.state()
print('Config save state:',ret) #Debug
if (ret == CMD_STATE_IDLE):
return True
elif (ret == CMD_STATE_ERROR):
print('Config save failed')
return False
def reset(self):
self.write_data([FEATURE_SYSTEM,CMD_SYS_RESET])
time.sleep(0.5)
def begin(self, algo, model, confidence):
error_count = 0
try:
self.system_id = visionAI.read_data_big_endian([FEATURE_SYSTEM,CMD_SYS_READ_ID],CMD_SYS_ID_LENGTH)
if (GROVE_AI_CAMERA_ID != self.system_id):
print('Not matching ID. Expected:',GROVE_AI_CAMERA_ID,'Received:',self.system_id)
return False
self.system_version = visionAI.read_data_big_endian([FEATURE_SYSTEM,CMD_SYS_READ_VERSION],CMD_SYS_VERSION_LENGTH)
self.algo_algo = visionAI.read_data([FEATURE_ALGO,CMD_ALGO_READ_ALGO],CMD_ALGO_ALGO_LENGTH)
self.algo_model = visionAI.read_data([FEATURE_ALGO,CMD_ALGO_READ_MODEL],CMD_ALGO_MODEL_LENGTH)
self.algo_confidence = visionAI.read_data([FEATURE_ALGO,CMD_ALGO_READ_CONFIDENCE],CMD_ALGO_CONFIDENCE_LENGTH)
if (algo != self.algo_algo or model != self.algo_model or confidence != self.algo_confidence):
self.write_data([FEATURE_ALGO,CMD_ALGO_WRITE_ALGO,algo])
self.write_data([FEATURE_ALGO,CMD_ALGO_WRITE_MODEL,model])
self.write_data([FEATURE_ALGO,CMD_ALGO_WRITE_CONFIDENCE,confidence])
if (algo != self.algo_algo):
print('Not matching Algo. Expected:',algo,'Received:',self.algo_algo)
error_count += 1
if (model != self.algo_model):
print('Not matching Model. Expected:',model,'Received:',self.algo_model)
error_count += 1
if (confidence != self.algo_confidence):
print('Not matching Confidence. Expected:',confidence,'Received:',self.algo_confidence)
error_count += 1
if (error_count != 0):
return False
if (not self.config_save()):
return False
self.reset()
except OSError as e:
if (e.errno == 5):
print('Model unknown')
if (e.errno == 121):
print('Reset Grove Vision AI Module')
print(OSError.__name__,':',e)
exit()
return True
def invoke(self):
self.write_data([FEATURE_ALGO,CMD_ALGO_INOVKE])
while(1):
ret = self.state()
print('Invoke state:',ret) #Debug
if (ret == CMD_STATE_RUNNING):
return True
print('Invoke failed')
return False
if __name__ == "__main__":
visionAI = VisionAI()
print('Address:',visionAI.address)
if (not visionAI.begin(ALGO_OBJECT_COUNT, MODEL_PRE_INDEX_1, 45)): #Bis jetzt geht nur MODEL_PRE_INDEX_1
print('Algo begin failed')
print('Version:',visionAI.system_version)
print('ID:',visionAI.system_id)
print('Algo:',visionAI.algo_algo)
print('Model:',visionAI.algo_model)
print('Confidence:',visionAI.algo_confidence)
if (visionAI.invoke()):
while(1):
ret = visionAI.state()
break
time.sleep(0.02)
print('People detected: ',visionAI.get_result_len())
