Using XIAO ESP32S3 Sense camera and mic simultaneously
The code examples for cam and mic both use I2S0.
I2S1 does not support PDM.
Is there a workaround for this to allow camera and mic to operate simultaneously?
Is there a reason an I2S mic was not supplied. It needs one more pin, but the D2/SD-CS pin is not needed if the SD card uses the MMC library.
Found out that although camara lib for ESP32 uses I2S0 DMA, the ESP32S3 uses GDMA, so PDM mic can be used simultaneously
