Hello, first-time XAIO user here, just starting on my first project.
I’m trying to get a Seeed Studio XAIO SAMD21 to go into bootloader mode, so that I can load a uf2 file into it. I’m working on a Linux Ubuntu 24.04.2 system.
When I first plug the SAMD21 into a USB-C cable connected to my system, I see this in dmesg:
[ 402.405636] usb 3-1.2: new full-speed USB device number 12 using xhci_hcd
[ 402.488950] usb 3-1.2: New USB device found, idVendor=2886, idProduct=802f, bcdDevice= 1.00
[ 402.488954] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 402.488955] usb 3-1.2: Product: Seeed femto M0
[ 402.488956] usb 3-1.2: Manufacturer: Seeed
[ 402.488957] usb 3-1.2: SerialNumber: DC85AFAA503058414E2E3120FF0B1801
[ 402.512956] cdc_acm 3-1.2:1.0: ttyACM0: USB ACM device
[ 402.512975] usbcore: registered new interface driver cdc_acm
[ 402.512977] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
As far as I can tell, this seems correct. The SAMD21 also seems to go into a BLINK program, flashing the yellow light once every 2 seconds.
When I short the RST pads together twice quickly, the yellow light goes into a ‘flicker’ mode, and this appears in dmesg:
[ 431.674139] usb 3-1.2: USB disconnect, device number 12
[ 432.614115] usb 3-1.2: new full-speed USB device number 13 using xhci_hcd
[ 432.691892] usb 3-1.2: New USB device found, idVendor=2886, idProduct=002f, bcdDevice=42.01
[ 432.691895] usb 3-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 432.691896] usb 3-1.2: Product: Seeeduino XIAO
[ 432.691898] usb 3-1.2: Manufacturer: Seeed Studio
[ 432.691899] usb 3-1.2: SerialNumber: DC85AFAA503058414E2E3120FF0B1801
[ 432.691970] usb 3-1.2: rejected 1 configuration due to insufficient available bus power
[ 432.691972] usb 3-1.2: no configuration chosen from 1 choice
I think the SAMD21 is going into bootloader mode correctly (flickering yellow light), but my Linux system isn’t registering it correctly as a volume that I can drag the uf2 file onto.
Can anyone tell me what’s happening, and how to set my system or the SAMD21 up correctly, so that I can program it with a uf2 file? Are there any other diagnostics I can run to see what’s happening?
Thanks for any advice and guidance.
-Kevin
