When I try to install the file from wiki SerialLCD_v1.0b_library.zip I get error
The compressed (zipped) Folder is invalid or corrupted.
Please help!!
What link did you download SerialLCD_v1.0b_library.zip?Try to update latest version for zip.
I use windows xp zip.
I downloaded WinZip 16.0 and that gives similar error message, invalid file
I choose link from wiki, site is garden.seeedstudio.com/images/e/e3/serialLCD_v1.0b_library.zip
I get the same error message with bluetoothShieldDemoCode.zip for the bluetooth shield.
I appreciate your help to get these library files.
I try the serialLCD_v1.0b_library.zip is find. And bluetoothShieldDemoCode.zip also find, there is no invalid or corrupted.
So i suggest you try to change another PC to test again.
Hi, thanks,I tried on three PC with the same result.
Can you provide the code and I can load it in myself?
I really need some help or information to use your display.
I need either more detail to write a library myself, including documentation for the intialization, working mode, commands and registers, or I need access to the library.
I am very flexible, I can work with a detailed document to interface with the display or code-text. Please let me know if you can provide so that I can use your part.
Thanks.
