My students are using Arduino IDE and Seeeduino Lotus Cortext M0+ (185 pcs.). Now the serial port of 14 of those boards is not found. I can’t select the Serial Port via Tools > Ports*
How can I fix this?
These boards worked before. I found I can get boards manually into bootloader mode (doubleclick the Reset) But this does not work with the failing boards.
It looks you are right, it is caused by 1.8.0. Explained in this post:
They provide a ‘solution’ to the problem. But It is far too complex and will take me more than a day. I have to wait till someone writes a more specific howto for this situation. ;-(
