Hi everyone,
I am trying to start to use seeeduino XIAO as a keyboard emulator.
The first time I sent the sketch to the XIAO everything was working fine.
I changed the sketch (minor change) and after that I cant no more upload a sketch. The port is detected but when trying to upload the ide says that the port was not found.
The sketch I originally uploaded is the next:
#include “Keyboard.h”
int buttonNum[5] = {3, 4, 2, 0, 1};
char KeySelected[5] = {‘a’, ‘b’, ‘c’, ‘d’ , ‘e’};
int buttSelect = 0;
Serial.begin(115200);
for (int x = 0; x < 5; x++) {
pinMode(buttonNum[x], INPUT_PULLUP);
Keyboard.begin();
int pressed = HIGH;
pressed = digitalRead(x);
if (pressed == LOW)
Keyboard.press(KeySelected[x]);
delay(50);
Keyboard.releaseAll();
delay(50);
pressed = -1;
delay(25);
The error that I am getting is:
/home/atex/Downloads/arduino-1.8.13/arduino-builder -dump-prefs -logger=machine -hardware /home/atex/Downloads/arduino-1.8.13/hardware -hardware /home/atex/.arduino15/packages -tools /home/atex/Downloads/arduino-1.8.13/tools-builder -tools /home/atex/Downloads/arduino-1.8.13/hardware/tools/avr -tools /home/atex/.arduino15/packages -built-in-libraries /home/atex/Downloads/arduino-1.8.13/libraries -libraries /home/atex/Arduino/libraries -fqbn=Seeeduino:samd:seeed_XIAO_m0:usbstack=arduino,debug=off -vid-pid=2886_802F -ide-version=10813 -build-path /tmp/arduino_build_715593 -warnings=none -build-cache /tmp/arduino_cache_497927 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/home/atex/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/home/atex/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.bossac.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS-Atmel.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1 -prefs=runtime.tools.arduinoOTA.path=/home/atex/.arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/atex/.arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.1 -verbose /home/atex/[email protected]/Arduino/keyboard/keyboard.ino
/home/atex/Downloads/arduino-1.8.13/arduino-builder -compile -logger=machine -hardware /home/atex/Downloads/arduino-1.8.13/hardware -hardware /home/atex/.arduino15/packages -tools /home/atex/Downloads/arduino-1.8.13/tools-builder -tools /home/atex/Downloads/arduino-1.8.13/hardware/tools/avr -tools /home/atex/.arduino15/packages -built-in-libraries /home/atex/Downloads/arduino-1.8.13/libraries -libraries /home/atex/Arduino/libraries -fqbn=Seeeduino:samd:seeed_XIAO_m0:usbstack=arduino,debug=off -vid-pid=2886_802F -ide-version=10813 -build-path /tmp/arduino_build_715593 -warnings=none -build-cache /tmp/arduino_cache_497927 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.openocd.path=/home/atex/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.openocd-0.10.0-arduino7.path=/home/atex/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino7 -prefs=runtime.tools.CMSIS.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.CMSIS-4.5.0.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0 -prefs=runtime.tools.arm-none-eabi-gcc.path=/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.arm-none-eabi-gcc-7-2017q4.path=/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs=runtime.tools.bossac.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.bossac-1.7.0-arduino3.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.7.0-arduino3 -prefs=runtime.tools.bossac-1.8.0-48-gb176eee.path=/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.8.0-48-gb176eee -prefs=runtime.tools.CMSIS-Atmel.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1 -prefs=runtime.tools.CMSIS-Atmel-1.2.1.path=/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1 -prefs=runtime.tools.arduinoOTA.path=/home/atex/.arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.1 -prefs=runtime.tools.arduinoOTA-1.2.1.path=/home/atex/.arduino15/packages/Seeeduino/tools/arduinoOTA/1.2.1 -verbose /home/atex/[email protected]/Arduino/keyboard/keyboard.ino
Using board ‘seeed_XIAO_m0’ from platform in folder: /home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6
Using core ‘arduino’ from platform in folder: /home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6
Detecting libraries used…
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=”"“keyboard.ino”""" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 /tmp/arduino_build_715593/sketch/keyboard.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for Keyboard.h: [[email protected] [email protected]]
ResolveLibrary(Keyboard.h)
-> candidates: [[email protected] [email protected]]
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=””“keyboard.ino””"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 -I/home/atex/Arduino/libraries/Keyboard/src /tmp/arduino_build_715593/sketch/keyboard.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Alternatives for HID.h: [[email protected]]
ResolveLibrary(HID.h)
-> candidates: [[email protected]]
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=””“keyboard.ino””"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 -I/home/atex/Arduino/libraries/Keyboard/src -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/libraries/HID /tmp/arduino_build_715593/sketch/keyboard.ino.cpp -o /dev/null -DARDUINO_LIB_DISCOVERY_PHASE
Using cached library dependencies for file: /home/atex/Arduino/libraries/Keyboard/src/Keyboard.cpp
Using cached library dependencies for file: /home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/libraries/HID/HID.cpp
Generating function prototypes…
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions “-D__SKETCH_NAME__=””“keyboard.ino””"" -w -x c++ -E -CC -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” “-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 -I/home/atex/Arduino/libraries/Keyboard/src -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/libraries/HID /tmp/arduino_build_715593/sketch/keyboard.ino.cpp -o /tmp/arduino_build_715593/preproc/ctags_target_for_gcc_minus_e.cpp -DARDUINO_LIB_DISCOVERY_PHASE
/home/atex/Downloads/arduino-1.8.13/tools-builder/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c+±kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino_build_715593/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch…
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m0plus -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -MMD “-D__SKETCH_NAME__=””“keyboard.ino””"" -DF_CPU=48000000L -DARDUINO=10813 -DARDUINO_SEEED_XIAO_M0 -DARDUINO_ARCH_SAMD -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” "-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -DARDUINO_SAMD_ZERO -D__SAMD21__ -D__SAMD21G18A__ -DARM_MATH_CM0PLUS -DSEEED_XIAO_M0 -DUSB_VID=0x2886 -DUSB_PID=0x802F -DUSBCON -DUSB_CONFIG_POWER=100 “-DUSB_MANUFACTURER=“Seeed”” "-DUSB_PRODUCT=“Seeed XIAO M0"” -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Include/ -I/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS-Atmel/1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/cores/arduino -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 -I/home/atex/Arduino/libraries/Keyboard/src -I/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/libraries/HID /tmp/arduino_build_715593/sketch/keyboard.ino.cpp -o /tmp/arduino_build_715593/sketch/keyboard.ino.cpp.o
Compiling libraries…
Compiling library “Keyboard”
Using previously compiled file: /tmp/arduino_build_715593/libraries/Keyboard/Keyboard.cpp.o
Compiling library “HID”
Using previously compiled file: /tmp/arduino_build_715593/libraries/HID/HID.cpp.o
Compiling core…
Using previously compiled file: /tmp/arduino_build_715593/core/variant.cpp.o
Using precompiled core: /tmp/arduino_cache_497927/core/core_Seeeduino_samd_seeed_XIAO_m0_usbstack_arduino,debug_off_411f057a50af809c2a5371fcc22770ca.a
Linking everything together…
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-g++ -L/tmp/arduino_build_715593 -Os -Wl,–gc-sections -save-temps -T/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0/linker_scripts/gcc/flash_with_bootloader.ld -Wl,-Map,/tmp/arduino_build_715593/keyboard.ino.map --specs=nano.specs --specs=nosys.specs -mcpu=cortex-m0plus -mthumb -Wl,–cref -Wl,–check-sections -Wl,–gc-sections -Wl,–unresolved-symbols=report-all -Wl,–warn-common -Wl,–warn-section-align -u _printf_float -u _scanf_float -o /tmp/arduino_build_715593/keyboard.ino.elf /tmp/arduino_build_715593/sketch/keyboard.ino.cpp.o /tmp/arduino_build_715593/libraries/Keyboard/Keyboard.cpp.o /tmp/arduino_build_715593/libraries/HID/HID.cpp.o /tmp/arduino_build_715593/core/variant.cpp.o -Wl,–start-group -L/home/atex/.arduino15/packages/Seeeduino/tools/CMSIS/4.5.0/CMSIS/Lib/GCC/ -larm_cortexM0l_math -L/home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/variants/XIAO_m0 -lm /tmp/arduino_build_715593/…/arduino_cache_497927/core/core_Seeeduino_samd_seeed_XIAO_m0_usbstack_arduino,debug_off_411f057a50af809c2a5371fcc22770ca.a -Wl,–end-group
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O binary /tmp/arduino_build_715593/keyboard.ino.elf /tmp/arduino_build_715593/keyboard.ino.bin
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-objcopy -O ihex -R .eeprom /tmp/arduino_build_715593/keyboard.ino.elf /tmp/arduino_build_715593/keyboard.ino.hex
Multiple libraries were found for “Keyboard.h”
Used: /home/atex/Arduino/libraries/Keyboard
Not used: /home/atex/Downloads/arduino-1.8.13/libraries/Keyboard
Using library Keyboard at version 1.0.1 in folder: /home/atex/Arduino/libraries/Keyboard
Using library HID at version 1.0 in folder: /home/atex/.arduino15/packages/Seeeduino/hardware/samd/1.7.6/libraries/HID
/home/atex/.arduino15/packages/Seeeduino/tools/arm-none-eabi-gcc/7-2017q4/bin/arm-none-eabi-size -A /tmp/arduino_build_715593/keyboard.ino.elf
Sketch uses 35108 bytes (13%) of program storage space. Maximum is 262144 bytes.
Forcing reset using 1200bps open/close on port /dev/ttyACM0
PORTS {/dev/ttyACM0, } / {/dev/ttyACM0, } => {}
Uploading using selected port: /dev/ttyACM0
/home/atex/.arduino15/packages/Seeeduino/tools/bossac/1.7.0-arduino3/bossac -i -d --port=ttyACM0 -U true -i -e -w -v /tmp/arduino_build_715593/keyboard.ino.bin -R
Set binary mode
Send auto-baud
Set binary mode
An error occurred while uploading the sketch
No device found on ttyACM0
Any help?
Thank you very much.
Best regards
Antonio Teixeira
