Hi Guys , using seeeduino lorawan and loaded the provided code in the seeeduino lorawan wiki here is the result I get (as you can see no success, for both code ), thank you in advance for your help :
@jiachenglu Please help to test it. This should be a minor problem
Hi @Froof
I got the same result as you. The possible reason is that you need to update to the latest version. I’m sorry that I haven’t found where the latest version is. I’ll give you a reply tomorrow. Please wait patiently.
Hello @Froof ,please try replace all of the Serial5 to Serial1,then try it again.
I have the same problem as @Froof.
@jiachenglu, in my case replacing all of the Serial5 to Serial1 produces this output
Any help will be appreciated.
Best regards,
Rafael
