Hi, I just bought ver 3.1 SD Card Shield and have not been able to find much information on it. Can you help me out with the Pin assignments for use with the Arduino Uno. Is this just Plug it in and use it with the libraries like Fat16.h and Fat16util.h or SDCard.h or any other libraries. And if so will I have to change Pin assignments in the library files. What pins does the SD Card Shield use for MOSI, MIOS, SCK, and SS? Thank-you for any help you can give me.
You can directly use the arduino “SD” library of arduino-1.0
And please note that the CS of this SD card Shield is 10.
Deray
Well I just found your SDCARD Arduino Sheild at Radio Shack. I was so excited not to pay the shipping. I bought one. I downloaded your software examples your the website. I tried both sides of the shield with various SD cards lexar 4GB micro, PNY 2GB micro, sandisk 4GB sd. I’ve been through this once before with your stalker version 1. Never got it to work. I’ve used the card as an ISP for my ATTINY programming so sad that I never got to log anything. I was dreaming of a fish tank parameter or water quality logger.
I tried another version of SD hardware for a china importer deal extreme. No joy on that one. Someone said it need a level shifter.
I wish some body would get some files that first compile and second actually work. I’ve downloaded so many versions of files from every possible source. Many of the files don’t even compile. I’ve tried old Ardruino version 22 and 1.0 and now the most recent version.
Your links take you to some beta file:
code.google.com/p/beta-lib/downl … p&can=2&q=
Ok so point me to your correct sketches and detail which board and hardware work with each other. By the way do you test your products before you sell them? There are many companies to choose from.
// Quick hardware test
#include <SdFat.h>
// Test with reduced SPI speed for breadboards.
// Change spiSpeed to SPI_FULL_SPEED for better performance
// Use SPI_QUARTER_SPEED for even slower SPI bus speed
const uint8_t spiSpeed = SPI_HALF_SPEED;
// Normally SdFat is used in applications in place
// of Sd2Card, SdVolume, and SdFile for root.
Sd2Card card;
SdVolume volume;
SdFile root;
// Serial streams
ArduinoOutStream cout(Serial);
// input buffer for line
char cinBuf[40];
ArduinoInStream cin(Serial, cinBuf, sizeof(cinBuf));
// SD card chip select
int chipSelect;
void cardOrSpeed() {
cout << pstr(
“Try another SD card or reduce the SPI bus speed.\n”
“The current SPI speed is: “);
uint8_t divisor = 1;
for (uint8_t i = 0; i < spiSpeed; i++) divisor *= 2;
cout << F_CPU * 0.5e-6 / divisor << pstr(” MHz\n”);
cout << pstr(“Edit spiSpeed in this sketch to change it.\n”);
void reformatMsg() {
cout << pstr(“Try reformatting the card. For best results use\n”);
cout << pstr(“the SdFormatter sketch in SdFat/examples or download\n”);
cout << pstr(“and use SDFormatter from www.sdcard.org/consumer.\n”);
// wait for Leonardo
while(!Serial) {}
cout << pstr(
“\nSD chip select is the key hardware option.\n”
“Common values are:\n”
“Arduino Ethernet shield, pin 4\n”
“Sparkfun SD shield, pin 8\n”
“Adafruit SD shields and modules, pin 10\n”);
bool firstTry = true;
// read any existing Serial data
while (Serial.read() >= 0) {}
if (!firstTry) cout << pstr("\nRestarting\n");
firstTry = false;
cout << pstr("\nEnter the chip select pin number: “);
cin.readline();
if (cin >> chipSelect) {
cout << chipSelect << endl;
} else {
cout << pstr(”\nInvalid pin number\n");
return;
if (!card.init(spiSpeed, chipSelect)) {
cout << pstr(
“\nSD initialization failed.\n”
“Do not reformat the card!\n”
“Is the card correctly inserted?\n”
“Is chipSelect set to the correct value?\n”
“Is there a wiring/soldering problem?\n”);
cout << pstr(“errorCode: “) << hex << showbase << int(card.errorCode());
cout << pstr(”, errorData: “) << int(card.errorData());
cout << dec << noshowbase << endl;
return;
cout << pstr(”\nCard successfully initialized.\n”);
cout << endl;
uint32_t size = card.cardSize();
if (size == 0) {
cout << pstr(“Can’t determine the card size.\n”);
cardOrSpeed();
return;
uint32_t sizeMB = 0.000512 * size + 0.5;
cout << pstr(“Card size: “) << sizeMB;
cout << pstr(” MB (MB = 1,000,000 bytes)\n”);
cout << endl;
if (!volume.init(&card)) {
if (card.errorCode()) {
cout << pstr(“Can’t read the card.\n”);
cardOrSpeed();
} else {
cout << pstr(“Can’t find a valid FAT16/FAT32 partition.\n”);
reformatMsg();
return;
cout << pstr(“Volume is FAT”) << int(volume.fatType());
cout << pstr(", Cluster size (bytes): ") << 512L * volume.blocksPerCluster();
cout << endl << endl;
root.close();
if (!root.openRoot(&volume)) {
cout << pstr(“Can’t open root directory.\n”);
reformatMsg();
return;
cout << pstr(“Files found (name date time size):\n”);
root.ls(LS_R | LS_DATE | LS_SIZE);
if ((sizeMB > 1100 && volume.blocksPerCluster() < 64)
|| (sizeMB < 2200 && volume.fatType() == 32)) {
cout << pstr("\nThis card should be reformatted for best performance.\n");
cout << pstr(“Use a cluster size of 32 KB for cards larger than 1 GB.\n”);
cout << pstr(“Only cards larger than 2 GB should be formatted FAT32.\n”);
reformatMsg();
return;
cout << pstr("\nSuccess! Type any character to restart.\n");
while (Serial.read() < 0) {}
Another one, doesn’t compile.
// modified from ArduinoTestSuite 0022 by William Greiman
// Tests writing to and reading from a file, in particular the
// the Stream implementation (e.g. read() and peek()).
#include <SdFat.h>
#include <SdFatTestSuite.h>
SdFat SD;
#define FILE_WRITE O_RDWR | O_CREAT | O_AT_END
#define ATS_PrintTestStatus(msg, b) testVerify_P(b, PSTR(msg))
boolean b;
SdFile f;
uint32_t fs;
testBegin(&Serial);
ATS_PrintTestStatus(“SD.init()”, b = SD.init());
if (!b) goto done;
SD.remove(“test.txt”);
f.open(“test.txt”, FILE_WRITE);
ATS_PrintTestStatus(“SD.open()”, f.isOpen());
if (!f.isOpen()) goto done;
f.print(“abc”);
f.print(“de”);
f.close();
f.print(“fgh”);
f.close();
f.open(“test.txt”, O_READ);
fs =f.fileSize();
ATS_PrintTestStatus(“read()”, f.read() == ‘a’);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘b’);
ATS_PrintTestStatus(“read()”, f.read() == ‘b’);
ATS_PrintTestStatus(“read()”, f.read() == ‘c’);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘d’);
ATS_PrintTestStatus(“read()”, f.read() == ‘d’);
ATS_PrintTestStatus(“available()”, f.curPosition() != fs);
ATS_PrintTestStatus(“read()”, f.read() == ‘e’);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘f’);
ATS_PrintTestStatus(“read()”, f.read() == ‘f’);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘g’);
ATS_PrintTestStatus(“read()”, f.read() == ‘g’);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘h’);
ATS_PrintTestStatus(“read()”, f.read() == ‘h’);
ATS_PrintTestStatus(“available()”, f.curPosition() == fs);
ATS_PrintTestStatus(“peek()”, f.peek() == -1);
ATS_PrintTestStatus(“read()”, f.read() == -1);
f.close();
SD.remove(“test2.txt”);
f.open(“test2.txt”, FILE_WRITE);
f.print(“ABC”);
f.close();
ATS_PrintTestStatus(“peek()”, f.peek() == ‘a’);
f.close();
f.open(“test2.txt”, O_READ);
ATS_PrintTestStatus(“peek()”, f.peek() == ‘A’);
ATS_PrintTestStatus(“read()”, f.read() == ‘A’);
f.close();
done:
testEnd();
void loop() {}
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Error inside Serial.serialEvent()
java.io.IOException: Bad file descriptor in nativeavailable
at gnu.io.RXTXPort.nativeavailable(Native Method)
at gnu.io.RXTXPort$SerialInputStream.available(RXTXPort.java:1532)
at processing.app.Serial.serialEvent(Serial.java:215)
Hi ,
Have you tried this library of arduin-1.0 ?
Deray
Success, I downloaded most recent Arduino program 1.0.1 without all the modded libraries. I remarked out the “//while (!Serial)” and set chipSelect = 10( I have a Deumi… board). All of the sample programs worked.
I plan to write a routine that reads a message off of an sd card and displays it on an LED matrix. Its doubtful I will make an aquarium monitor since getting all the sensors is complex and expensive.
I apologize, my above remarks were overly emotional and an I don’t want to falsely accuse. I’ll revisit the stalker card.
