reTerminal making a high pitched sound while powered on
update: I managed to get the device booting correctly with a newly installed OS, and everything looks fine. But the squealing tone remains.
did you try powering from a battery or a different source, like a battery bank or different computer?
BAD cap or crappy power supply. try what cG said see what you hear :+1:
:v:
On battery it should go away completely , or it means there is a bad cap in it.
the noise is constant on battery or any of the various USB power adapters I’ve tried.
Time to open it up and give a visual inspection.
look for any swollen capacitors or perhaps some corrosion near the power port. Snap a picture and post it up, we can look to. Could also be a cold solder joint, has it done it from the beginning?
:v:
also try a different AC plug for the power supply. with no other devices , if it is a power strip. :+1:
In my case it was the buzzer that was causing the problem.
I fixed it by stuffing something into the buzzer hole.
LOL,
That’s hardly a fix though c’mon man… :smile:
more like fixed the symptom not the problem , pretty funny though. :face_with_hand_over_mouth:
:v:
the XIAO Expansion board will do that too when the 3 pin floats… usually on some type of coms…
Same here since today. Out of the blue my reTerminal 1001 started to make 3 short beeps each time it powers on for refresh. Annoying. I wonder if I should try to replace it.
