When using gpiod tools to view the GPIO pins on the device, there are three “chips”.
CHIP 2 contains the LED’s on the front panel. The one marked USR on the panel is known as “usr_led0” and is at index 4, and shows all lines as being “used” in :
gpioinfo gpiochip2
Since I want to use this LED on the front panel as an indicator in a C++ program it will have to be controlled by libgpio, but how do I release usr_led0 from being “used”???
Regards,
Mitch
pi@reterminal:~ $ gpioinfo gpiochip2
gpiochip2 - 8 lines:
line 0: unnamed "usr_btn0" input active-low [used]
line 1: unnamed "usr_btn2" input active-low [used]
line 2: unnamed "usr_btn1" input active-low [used]
line 3: unnamed "usr_btn3" input active-low [used]
line 4: unnamed "usr_led0" output active-low [used]
line 5: unnamed "usr_led1" output active-low [used]
line 6: unnamed "usr_led2" output active-low [used]
line 7: unnamed "usr_buzzer" output active-high [used]
I see the definition in the overlay file for the USER LED device as well. I don’t have enough knowledge on dt overlays to attempt to modify it.
Now I cannot find the file with the overlay defs in it. Anyone at all know how to release the usr_led0 from being “used” at boot?
