reTerminal E1002 Color ePaper Display - Home Assistant Dashboard
I got a reTerminal E1002 and thought I’d share my dashboard and ESPHome code. I also have a XIAO 7.5" ePaper Display and was able to use a lot of the code from that project.
The E100x displays have a much better build (metal case) with programmable buttons, MicroSD card support, leds and buzzer. It also has battery status which was my biggest issue with the XIAO 7.5".
The biggest con to the E1002 (color version) is that the refresh takes a long time (sometimes 30 secs) because it looks like it flashes every color for every element. It flashes like crazy while doing the refresh. I don’t have and numbers yet, but it looks like the battery life is less that the B&W epaper. I’ll update this topic when I have a rough number of days.
I’m still messing with the colors. Haven’t settled on what works best yet.
Pictures:
You will need the Puppet Addon.
ESPHome Builder YAML:
esphome:
  friendly_name: ColorEinkDisplay
  on_boot:
    - priority: 600
      then:
        - output.turn_on: bsp_sd_enable
        - output.turn_on: bsp_battery_enable
        - delay: 200ms
        - component.update: battery_voltage
        - component.update: battery_level
    - priority: -100
      then:
        - logger.log: "*** Device woke up from deep sleep ***"
        - light.turn_on: onboard_led
        - delay: 1s
        - logger.log: "*** Starting application ***"
esp32:
  board: esp32-s3-devkitc-1
  framework:
#    type: arduino
    type: esp-idf
# Enable logging
logger:
  hardware_uart: UART0
# Enable Home Assistant API
api:
  encryption:
    key: "<Your API Key>"
  on_client_connected:
    - logger.log:
        format: "*** Client %s connected to API with IP %s ***"
        args: ["client_info.c_str()", "client_address.c_str()"]
ota:
  - platform: esphome
    password: "<Your OTA PW>"
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_password
  min_auth_mode: WPA2
  on_connect:
    then:
      - lambda: |-
          id(wifi_status) = 1;
      - logger.log: "*** WiFi Connected Successfully! ***"
      - delay: 1s
      - component.update: dashboard_image
  on_disconnect:
    then:
      - lambda: |-
          id(wifi_status) = 0;
      - logger.log: "*** WiFi Disconnected ***"
  ap:
    ssid: "ColoreInkFallbackHotspot"
    password: "<Your Fallback Hotspot PW>"
psram:
  mode: octal
  speed: 80MHz
captive_portal:
globals:
  - id: sleep_counter
    type: int
    restore_value: yes  # Use RTC storage to maintain counter during sleep
    initial_value: '0'
  - id: battery_glyph
    type: std::string
    restore_value: no
    initial_value: "\"\\U000F0079\""   # default full battery
  - id: wifi_status
    type: int
    restore_value: no
    initial_value: "0"
  - id: recorded_display_refresh
    type: int
    restore_value: yes
    initial_value: '0'
# Deep-sleep, wake by GPIO3
deep_sleep:
  run_duration: 120s  # Device wake up and run 120s. This should not run for 120s because of other code
  sleep_duration: 30min  # deep sleep for 30m
  wakeup_pin: GPIO3          # Green button
  wakeup_pin_mode: INVERT_WAKEUP
# SPI bus for display
spi:
  clk_pin: GPIO7
  mosi_pin: GPIO9
# I2C bus for temperature and humidity sensor
i2c:
  scl: GPIO20
  sda: GPIO19
http_request:
  verify_ssl: false
  timeout: 20s
  watchdog_timeout: 25s
online_image:
  - id: dashboard_image
    format: PNG
    type: RGB565
    buffer_size: 65536
    url: http://192.168.1.101:10000/dashboard-robin/display-color?viewport=800x480&lang=en
#    update_interval: 20s.  # Not needed now
    on_download_finished:
      - component.update: epaper_display
      - delay: 45s # Time to allow display to refresh
      - deep_sleep.enter: deep_sleep_1
    on_error:
      - delay: 30s
display:
  - platform: epaper_spi
    model: Seeed-reTerminal-E1002
    update_interval: never
    lambda: |-
      it.image(0, 0, id(dashboard_image));
# Home Assistant time
time:
  - platform: homeassistant
sensor:
  - platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
    update_interval: 60s
    name: "WiFi Signal dB"
    entity_category: "diagnostic"
  - platform: copy # Reports the WiFi signal strength in %
    source_id: wifi_signal_db
    name: "WiFi Signal Percent"
    filters:
      - lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
    unit_of_measurement: "%"
  - platform: uptime
  - platform: internal_temperature
    name: "Internal Temperature"
  - platform: template
    name: "Display Last Update"
    device_class: timestamp
    lambda: 'return id(ha_time).now().timestamp;'
    name: "Display Refresh Count"
    accuracy_decimals: 0
    unit_of_measurement: "Refreshes"
    state_class: "total_increasing"
    lambda: 'return id(recorded_display_refresh) += 1;'
  - platform: sht4x
    temperature:
    humidity:
      name: "Relative Humidity"
  - platform: adc
    pin: GPIO1
    attenuation: 12db
    filters:
      - multiply: 2.0
    icon: "mdi:battery"
    device_class: battery
    state_class: measurement
    lambda: 'return id(battery_voltage).state;'
    on_value:
      then:
        - lambda: |-
            int pct = int(x);
            if (pct <= 10)      id(battery_glyph) = "\U000F007A";
            else if (pct <= 20) id(battery_glyph) = "\U000F007B";
            else if (pct <= 30) id(battery_glyph) = "\U000F007C";
            else if (pct <= 40) id(battery_glyph) = "\U000F007D";
            else if (pct <= 50) id(battery_glyph) = "\U000F007E";
            else if (pct <= 60) id(battery_glyph) = "\U000F007F";
            else if (pct <= 70) id(battery_glyph) = "\U000F0080";
            else if (pct <= 80) id(battery_glyph) = "\U000F0081";
            else if (pct <= 90) id(battery_glyph) = "\U000F0082";
            else                id(battery_glyph) = "\U000F0079";
    filters:
      - calibrate_linear:
          - 4.15 -> 100.0
          - 3.96 -> 90.0
          - 3.91 -> 80.0
          - 3.85 -> 70.0
          - 3.80 -> 60.0
          - 3.75 -> 50.0
          - 3.68 -> 40.0
          - 3.58 -> 30.0
          - 3.49 -> 20.0
          - 3.41 -> 10.0
          - 3.30 -> 5.0
          - 3.27 -> 0.0
      - clamp:
          min_value: 0
          max_value: 100
# Button configuration
binary_sensor:
#  - platform: gpio
#    pin:
#      number: GPIO3         # Green button, commented out because I'm using it for wakeup
#      mode: INPUT_PULLUP
#      inverted: true
#    id: button_1
#    name: "Green Button"
#    on_press:
#      then:
#        - logger.log: "*** Green Button (GPIO3) Pressed ***"
  - platform: gpio
    pin:
      number: GPIO4          # Right white button
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - logger.log: "*** Right Button (GPIO4) Pressed ***"
  - platform: gpio
    pin:
      number: GPIO5           # Left white button
      mode: INPUT_PULLUP
      inverted: true
    on_press:
      then:
        - logger.log: "*** Left Button (GPIO5) Pressed ***"
output:
  - platform: gpio
    pin: GPIO6
    inverted: true
  - platform: gpio
    pin: GPIO16
  - platform: gpio
    pin: GPIO21
# Onboard LED
light:
  - platform: binary
    output: bsp_led
Home Assistant Dashboard YAML:
type: masonry
path: display-color
title: Display-Color
cards:
  - type: vertical-stack
    cards:
      - show_current: true
        show_forecast: true
        type: weather-forecast
        entity: weather.kpajamis12
        forecast_type: daily
        secondary_info_attribute: humidity
        card_mod:
          style: |
            :host {
              --weather-icon-cloud-front-color: white;
              --weather-icon-cloud-back-color: black;
              --weather-icon-sun-color: yellow;
              --weather-icon-rain-color: blue;
              --weather-icon-moon-color: yellow;
            ha-card {
              border: 2px solid black;
              padding: 5px !important;
              background: red;
            .name-state .name {
              color: blue;
              font-size: 16px;
            .name-state .state {
              color: yellow;
              font-weight: bold;
            .temp-attribute .temp {
              color: yellow;
              font-weight: bold;
              font-size: 30px !important;
            .temp-attribute .temp span {
              color: yellow;
              font-size: 20px !important;
            .temp-attribute .attribute {
              color: white;
              font-size: 16px;
            .forecast .temp {
              color: yellow;
              font-weight: bold;
              font-size: 14px;
            .forecast .templow {
              color: white;
              font-weight: bold;
              font-size: 14px;
            .forecast div {
              font-weight: bold;
              color: white;
            ha-card div.forecast div.temp {
              font-size: 14pt;
      - type: horizontal-stack
        cards:
          - graph: line
            type: sensor
            detail: 2
            entity: sensor.home_thermostat_air_temperature
            icon: mdi:home-thermometer
            hours_to_show: 12
            card_mod:
              style: |
                .header .icon {
                  color: white;
                ha-card {
                  --primary-text-color: yellow;
                  font-weight: bold;
                  --secondary-text-color: white;
                  background: green;
                  --accent-color: white;
                  --ha-font-size-3xl: 46px;
          - graph: line
            type: sensor
            detail: 2
            icon: mdi:sun-thermometer-outline
            hours_to_show: 12
            entity: sensor.back_deck_temp_temperature
            card_mod:
              style: |
                .header .icon {
                  color: white;
                ha-card {
                  font-weight: bold;
                  background: green;
        cards:
          - graph: none
            type: sensor
            detail: 2
            icon: ""
            hours_to_show: 12
            entity: sensor.back_deck_temp_humidity
            card_mod:
              style: |
                .header .icon {
                  color: white;
                ha-card {
                  --primary-text-color: white;
                  font-weight: bold;
                  background: blue;
          - graph: none
            type: sensor
            detail: 2
            entity: sensor.topwindspeedhr
            icon: mdi:weather-windy
            hours_to_show: 12
            card_mod:
              style: |
                .header .icon {
                  color: white;
                ha-card {
                  font-weight: bold;
                  background: blue;
          - graph: none
            type: sensor
            detail: 2
            icon: ""
            hours_to_show: 24
            entity: sensor.kpajamis12_precipitation_today
            card_mod:
              style: |
                .header .icon {
                  color: white;
                ha-card {
                  font-weight: bold;
                  background: blue;
    cards:
      - type: custom:mushroom-chips-card
        chips:
          - type: entity
            entity: sensor.date_time
            icon_color: yellow
            card_mod:
              style: |
                ha-card {
                  --chip-background: green;
                  --chip-height: 20px;
                  --chip-border-radius: 12px;
                  --chip-icon-size: 12px;
                  --chip-font-size: 12px;
                  --text-color: yellow;
                  border: 2px solid black !important;
          - type: spacer
          - type: entity
            entity: sensor.coloreinkdisplay_wifi_signal_percent
            icon_color: yellow
            card_mod:
              style: |
                ha-card {
          - type: entity
            entity: sensor.coloreinkdisplay_battery_level
            icon_color: yellow
            card_mod:
              style: |
                ha-card {
        alignment: center
      - entities:
          - entity: calendar.birthdays
            show_time: true
            color: white
            accent_color: white
          - entity: calendar.philadelphia_phillies
            show_time: true
            color: white
            accent_color: white
          - entity: calendar.carolina_panthers
            show_time: true
            color: white
            accent_color: white
          - entity: calendar.holidays_in_united_states
            show_time: true
            split_multiday_events: false
            color: white
            accent_color: white
          - entity: calendar.north_carolina_tar_heels_men_s_basketball
            show_time: true
            color: white
            accent_color: white
          - entity: calendar.philadelphia_eagles
            show_time: true
            color: white
            accent_color: white
          - entity: calendar.john_w_waters_gmail_com
            show_time: true
            color: white
            accent_color: white
        days_to_show: 7
        show_empty_days: true
        filter_duplicates: true
        title: ""
        title_color: ""
        background_color: black
        accent_color: white
        day_spacing: 4px
        event_spacing: 2px
        day_separator_width: 1px
        day_separator_color: yellow
        today_indicator: dot
        today_indicator_color: green
        weekday_color: white
        day_color: white
        month_color: white
        weekend_weekday_color: yellow
        weekend_day_color: yellow
        weekend_month_color: yellow
        today_weekday_color: ""
        today_day_color: ""
        today_month_color: ""
        show_past_events: true
        event_font_size: 20px
        event_color: white
        empty_day_color: white
        time_font_size: 14px
        time_color: white
        show_location: false
        weather:
          position: none
          date:
            show_conditions: true
            show_high_temp: true
            show_low_temp: false
            icon_size: 14px
            font_size: 12px
            color: white
          event:
            show_temp: true
            icon_size: 14px
            font_size: 12px
            color: white
        type: custom:calendar-card-pro
        height: 400px
        card_mod:
          style: |
            ha-card {
              font-weight: bold !important;
            .day-table.today .event-title {
            .day-table.tomorrow .event-title {
            .day-table.future-day .event-title {
            div.time {
badges: []
John
Excellent Work, right there. Solid solution example too. :+1:
They are on Backorder now, so the Live stream win Unit is OTW :grin:
The Awesome Seeed order support e-mailed me the status, above and beyond :v:
I like the Solid Metal back WOW :star_struck: Stepped up the Display game fo Sho!
I wonder if there is a clock freq change or something along those lines for the Refresh issues I see posted.
cutting edge tech, so expect a few cuts :grin:
I’m going to get some dimensions for some color 3D printed bezel or Frame (wall mounts)?
Wow, that looks really cool! The E1002 seems way more solid than the XIAO with the metal case and buttons, but yeah, that color refresh looks slow. I’d love to hear how long the battery lasts and which colors you end up using.
Here’s a couple of videos of the display updating (flashing). It seems like the length is related to how many colors you use. First one uses all colors. Second one is B&W.
Color
B&W
And yes, I need to clean the screen. :grin:
I hope that is NOT normal operation :face_with_peeking_eye:…Something is up , maybe it’s trying to Do a full refresh when just a partial will do. Also the timing seems off. If you look at the E-ink video I posted with the 4.2 inch display on here it’s was also like that in the beginning
Something with the Blank refresh or partial. I’ll need to look again at it, since its been a while and the LIVE stream unit I won is in transit, so I’ll have some hands on, and look at the code too! :+1:
Did you get your unit yet?
Nuttin yet… :sleepy_face:
:v:
PJ
Battery life seems to be about 1/2 of the B&W model. I’m sure this is due to the long refresh times.
It looks like it last about 18 days with every 30 mins refreshes that are live for 45 secs. I’m charging it again now and will start a new battery days counter.
I did find a parameter to control when to do a full refresh, but I’m not sure if this display supports it. I’m trying it out now.
full_update_every: (Optional, int): On screens that support partial updates, this sets the number of updates before a full update is forced. Defaults to 1 which will make every update a full update.
display:
    full_update_every: 10
    lambda: |-
DAMIT
:grin:
My FOMO is killing me, c’mon DHL or MailMan… :joy:
meanwhile… Nice info on the battery life. :+1: any code optimisation for the SLEEP on the CPU in there?
Yea, those refresh’s are the Achilles heel of these things, but for the over-all power savings from a Always ON display.. I’m paying attention.
I was looking at a Reset in the morning type setup with a light sensor. to wake up from power down sleep (off) and get to working & refreshing.
It goes into a Deep Sleep after 45 secs (enough time to refresh + a little extra time). It sleeps for 30 mins, wakes for 45s, and so on.
If it’s able to do a partial refresh, that will probably help a lot because most of my screen doesn’t change between refreshes. I have to do more testing, but it doesn’t look like the partial refresh is working.
Stellar work , my guy :grin: :+1:
Yep , I’m feeling there has got to be a partial it makes all the difference, I posted the E-ink 4.2 inch video and code on here. Turns out the partial refresh is the Key to a smooth and fast looking display, they have got to know it, but may be still in the works on such NEW hardware :crossed_fingers:
Last battery update. 30 min refreshes. Around 16 days.
Dear all,
I am new to the seeed studio reterminal e1002. I am not so sure if you can help. I have followed the instructions to set up the terminal and got it connected to the WiFi. However, I did not write down the pair code at that time. I tried to connect the terminal to the SenceCraft HMI, when I press the add new device, I have to provide that information and it is nowhere I can find the code anymore. I tried to open it up and press the reset button, refresh, unplug the battery, etc. However, when I reset the terminal, it goes to the page “WiFi Connected” with the IP address. Unfortunately, I still cannot find the Pair Code for the HMI register. Is it possible for me to recover the code or hard reset so that the code will appear again?
Thanks a lot for your help and it is much appreciated!
Kind regards,
Luke
