Respeaker on raspberry Pi
I have bought 2 ReSpeakers 4-Mic Array for Raspberry Pi and I’m trying to
set them up on a new Raspberry Pi B+ with a clean build of Raspian.
I am using this document for setting up:
http://wiki.seeedstudio.com/ReSpeaker_4_Mic_Array_for_Raspberry_Pi/#getting-started
At step 4 of install driver section when I run arecord -L I see:
pi@raspberrypi:~/seeed-voicecard $ arecord -L
null
Discard all samples (playback) or generate zero samples (capture)
default
playback
ac108
I have tried rebuild of raspbian and using 2 different Pis. Please help.
Mat Walker
Hi
Mat,
1. Do you use Raspberry Pi 1 Model B+?
2. Which raspbian os do you use? We tested with latest raspbian OS Version: April 2019, Release date: 2019-04-08, Kernel version: 4.14, It works with my raspberry pi 3b/3b+.
3. We have build the image with drivers pre-installed. You can download and burn to SD card and see if it works.
4. Please let us know if you still have the issue with step3.
best rgds
Bill
Hi Bill,
Thanks for your reply.
It’s a new Raspberry Pi 3 Model B +. I have two of them for a project with
Noobs SIM cards and I started with a clean install with latest OS:
Raspbian GNU/Linux 9 (stretch)
version 9 (stretch)
4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST armv71 GNU/Linux
I found this on the forum yesterday with the same problem:
https://forum7.seeedstudio.com/t/4-mic-linear-array-not-recognized/6678/2
Resinstalling the driver didn’t help but using your image solved the
problem. Your image takes me to an earlier core:
v4.14.52-v7+ #1123 SMP Wed Jun 27 17:35:49 SBST 2018 armv71 GNU/Linux
Next problem was that all the pip installs for DOA without keywords are
for Python 2. I resolved this by using pip3 and manually fixing Queue to
queue in mic_array.py.
Final problem was that the LED instructions are very confusing. The
vad_doa.py example in the Raspberry Pi instructions uses
pixel_ring.set_direction and this doesn’t work giving USB not found error.
Found this article
https://github.com/respeaker/mic_array/issues/18
So everything is working fine now.
Hope this helps. Maybe some of this information could go in the getting
started document.
Mat Walker
Hi Bill,
version 9 (stretch)
Found this article
started document.
Mat Walker
HI Mat,
I talked with software team and they fixed the issue. So please run below commands as below.
sudo ./uninstall.sh
sudo reboot
sudo ./install.sh
sudo reboot
pi@raspberrypi:~ $ uname -a
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
pi@raspberrypi:~ $ arecord -l
**** List of CAPTURE Hardware Devices ****
card 1: seeed4micvoicec [seeed-4mic-voicecard], device 0: bcm2835-i2s-ac10x-codec0 ac10x-codec.1-003b-0 []
Subdevices: 1/1
Subdevice #0: subdevice #0
pi@raspberrypi:~ $
best rgds
Bill
Hi Bill,
Thanks for sorting out the driver. I’ll try this next week once my event
is over. I have a stable, working system using your image.
Best regards,
Mat Walker
Hi Bill,
Best regards,
Mat Walker
