Odyssey WiFi antenna
Had anyone found a better wifi antenna solution for the Odyssey? Since it is mounted in an aluminum case and seems to have a +1 or +3db antenna I’m not getting any wifi range. It would be nice to have an option for a +6 or +9db antenna package.
@marki763 You can ref this.
https://www.mouser.com/ProductDetail/Taoglas/CABS01?qs=%2Fv8iy7V9uiylJ75x4lhCJw==
https://www.mouser.com/ProductDetail/Fanstel/ANT060?qs=wUXugUrL1qykGqRu8ipXOw==
Can’t we use this antenna for “EM06-E LTE M.2 Module” ?
Hi @RY_93
The EM06-E LTE M.2 Module needs special antennas that need to be customized by an antenna manufacturer. We have contacted the manufacturer of this module and this is their opinion.
Thanks.
Can we use any other M.2 LTE Module ?
What are the compatibility parameters( other than the form factor , key socket and region support) we have to look ?
Hi @RY_93
The antenna needs to be combined with the whole machine to debug the RF performance, the antenna factory will assist.
Here is the specification.
Would I need both the Taoglas and the Fanstel ???
Still couldn’t figure out what the antenna connector of the Odyssey is: MH4 or u.FL
Wifi module connector is IPEX MH4
Thank you!
Best regards
Thanks Bruce. It would be good if seeed offered this as an antenna alternative
Adding $20 to my u it
When are the 4G antennas going to be available? Ive been waiting since September?!?!?
:sweat_smile::sweat_smile::sweat_smile:
