I have ordered 2x MR60BHA1 60GHz radar module recently, I have tested both modules to my laptop with the original Human Vital Sign Radar Software that is provided by Seeed Studio. But both device give no measurement on the Breathrate window and graph. The hardrate window displays a value that is around 15 So that would be more likely a plausible Breatrate value, however when I breath very fast for a minute this value does not change a lot, So it is probably not the breathrate as well. The Movement display works fine.
I also added a steady 5V external powersupply because I tought that was the issue, but it makes no improvement.
I also observed the bare values by a terminal program, but these bare values showing the same incorrect numbers.
I hope one of you can help me getting the modules to work.
Thanks,
Xander
After analysis of the output frames, non of them is coherent with respect to the protocol described in the documentation. Maybe is there an update of the documentation ? Thank you.
