Can someone please send me the spec for the microphones used on the ReSpeaker 6-Mic Circular Array kit?
Also does any one know what the minimum distance is between the microphones?
Thanks,
Brad.
Hi Brad,
Here is the latest mics, you can see as below picture.
Here is the datasheet.
<LINK_TEXT text=“https://github.com/SeeedDocument/forum_ … %B9%A6.pdf”>https://github.com/SeeedDocument/forum_doc/raw/master/312030322%2C%20SMD%20Mic%20OMNI-32DB%3B4P-L3.76XW2.95XH1.2mm-物料规格书.pdf</LINK_TEXT>
The distance between 2 mics is around 45mm. thanks.
