Login for prebuilt image?
hi what is the login for prebuilt image please, i assume ssh is enabled by default?
also image seems very old (bullseye?)
Should be username: respeaker and password: respeaker
hi, unfortunantly that does not seem to work :frowning: (i also tried logging in direct instead of ssh)
i tried following the git clone method to install the drivers on a fresh raspberry pi image, but each time i run the script i just end up in a “firmware upgrade loop”, in that when i restart the pi and rerun the script, the below terminal output just reoccurs again and again
Reading state information... Done
dkms is already the newest version (2.8.4-3).
git is already the newest version (1:2.30.2-1+deb11u3).
i2c-tools is already the newest version (4.2-1+b1).
libasound2-plugins is already the newest version (1.2.2-2).
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
dpkg-query: package 'linux-headers-' is not installed
dpkg-query: package '6.1.21+' is not installed
Use dpkg --contents (= dpkg-deb --contents) to list archive files contents.
 !!! Your kernel version is
6.1.21+
     Not found *** corresponding *** kernel headers with apt-get.
     This may occur if you have ran 'rpi-update'.
 Choose  *** y *** will revert the kernel to version  then continue.
 Choose  *** N *** will exit without this driver support, by default.
Would you like to proceed? (y/N)
Reading package lists... Done
Building dependency tree... Done
0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 2 not upgraded.
Need to get 0 B/102 MB of archives.
After this operation, 0 B of additional disk space will be used.
(Reading database ... 177532 files and directories currently installed.)
Preparing to unpack .../raspberrypi-kernel_1%3a1.20230405-1_armhf.deb ...
run-parts: executing /etc/kernel/prerm.d/dkms 6.1.21+ /boot/kernel.img
run-parts: executing /etc/kernel/prerm.d/dkms 6.1.21-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/prerm.d/dkms 6.1.21-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/prerm.d/dkms 6.1.21-v8+ /boot/kernel8.img
Adding 'diversion of /boot/kernel.img to /usr/share/rpikernelhack/kernel.img by rpikernelhack'
Adding 'diversion of /boot/kernel7.img to /usr/share/rpikernelhack/kernel7.img by rpikernelhack'
Removing 'diversion of /boot/overlays/wittypi.dtbo to /usr/share/rpikernelhack/overlays/wittypi.dtbo by rpikernelhack'
Removing 'diversion of /boot/overlays/wm8960-soundcard.dtbo to /usr/share/rpikernelhack/overlays/wm8960-soundcard.dtbo by rpikernelhack'
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 6.1.21+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/dkms 6.1.21+ /boot/kernel.img
/etc/kernel/postinst.d/dkms:
dkms: running auto installation service for kernel 6.1.21+:.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 6.1.21+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 6.1.21+ /boot/kernel.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 6.1.21-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/dkms 6.1.21-v7+ /boot/kernel7.img
dkms: running auto installation service for kernel 6.1.21-v7+:.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 6.1.21-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 6.1.21-v7+ /boot/kernel7.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 6.1.21-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/dkms 6.1.21-v7l+ /boot/kernel7l.img
dkms: running auto installation service for kernel 6.1.21-v7l+:.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 6.1.21-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 6.1.21-v7l+ /boot/kernel7l.img
run-parts: executing /etc/kernel/postinst.d/apt-auto-removal 6.1.21-v8+ /boot/kernel8.img
run-parts: executing /etc/kernel/postinst.d/dkms 6.1.21-v8+ /boot/kernel8.img
dkms: running auto installation service for kernel 6.1.21-v8+:.
run-parts: executing /etc/kernel/postinst.d/initramfs-tools 6.1.21-v8+ /boot/kernel8.img
run-parts: executing /etc/kernel/postinst.d/unattended-upgrades 6.1.21-v8+ /boot/kernel8.img
 WARNING Your loaded kernel version is 6.1.21
 Not matching the updated version
6.1.21.
 Kernel was updated, but new kernel was not loaded yet
 Please reboot your machine AND THEN run this script again
PS My install script procedure …
git clone https://github.com/respeaker/seeed-voicecard.git
cd seeed-voicecard/
sudo ./install.sh 2mic
I had the same issue with the install and cannot find the user name and password for the pre-built image
I also tried this username and password and it fails to login.
Thank you for your feedback. Next, we will conduct a test. If there are any progress or solutions, we will announce them here.
