Hello-
Our company purchased a Seeed A206 carrier board and Jetson TX2 NX.
I have followed the steps on
https://wiki.seeedstudio.com/Tutorial-of-A20X-Carrier-Boards/
Using SDKManager, during install I get an error
00:26:18 INFO: Flash Jetson TX2 - flash: UnicodeDecodeError: 'utf-8' codec can't decode byte 0xa4 in position 17: invalid start byte
00:26:18 INFO: Flash Jetson TX2 - flash: --- Error: Reading board information failed.
00:26:18 ERROR: Flash Jetson TX2 - flash: command terminated with error
I repeated the install, and got the same error.
I then switched to command line install per the wiki page, and it appears to have completed successfully. However, upon reboot of the Jetson, The boot sequence hangs: The NVIDIA splash screen appears, then the text boot log begins filling eventually hanging at the line shown in the attached picture.
I’ve also attached the full shell log of the command line install to show that it appears to have succeeded.
(I had to clip the shell log because the forum has a message length limit and uploading of *.txt files is not allowed).
Where can I get support for this carrier board? How can I resolve this error?
Thanks,
-Eric.
ebrandt@ubu1804:~/Downloads$ ls -l
total 1949376
-rw-rw-r-- 1 ebrandt ebrandt 371419060 Sep 23 13:04 Jetson_Linux_R32.6.1_aarch64.tbz2
drwxrwxr-x 3 ebrandt ebrandt 4096 Aug 19 10:36 nvidia
-rw-rw-r-- 1 ebrandt ebrandt 124957828 Aug 19 10:31 sdkmanager_1.8.1-10392_amd64.deb
-rw-rw-r-- 1 ebrandt ebrandt 1499762780 Sep 23 13:05 Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
ebrandt@ubu1804:~/Downloads$ export L4T_RELEASE_PACKAGE=Jetson_Linux_R32.6.1_aarch64.tbz2
ebrandt@ubu1804:~/Downloads$ export SAMPLE_FS_PACKAGE=Tegra_Linux_Sample-Root-Filesystem_R32.6.1_aarch64.tbz2
ebrandt@ubu1804:~/Downloads$ echo ${L4T_RELEASE_PACKAGE}
ebrandt@ubu1804:~/Downloads$ echo ${SAMPLE_FS_PACKAGE}
ebrandt@ubu1804:~/Downloads$ export BOARD=jetson-xavier-nx-devkit-tx2-nx
ebrandt@ubu1804:~/Downloads$ lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 006: ID 0451:ca01 Texas Instruments, Inc.
Bus 001 Device 007: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 005: ID 0451:8027 Texas Instruments, Inc.
Bus 001 Device 003: ID 0451:8142 Texas Instruments, Inc. TUSB8041 4-Port Hub
Bus 001 Device 002: ID 0a5c:21e8 Broadcom Corp. BCM20702A0 Bluetooth 4.0
Bus 001 Device 012: ID 0955:7c18 NVidia Corp.
Bus 001 Device 004: ID 1a40:0101 Terminus Technology Inc. Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
ebrandt@ubu1804:~/Downloads$ tar xf ${L4T_RELEASE_PACKAGE}
ebrandt@ubu1804:~/Downloads$ cd Linux_for_Tegra/rootfs/
ebrandt@ubu1804:~/Downloads/Linux_for_Tegra/rootfs$ sudo tar xpf ../../${SAMPLE_FS_PACKAGE}
[sudo] password for ebrandt:
ebrandt@ubu1804:~/Downloads/Linux_for_Tegra/rootfs$ cd ..
ebrandt@ubu1804:~/Downloads/Linux_for_Tegra$ sudo ./apply_binaries.sh
Using rootfs directory of: /home/ebrandt/Downloads/Linux_for_Tegra/rootfs
Installing extlinux.conf into /boot/extlinux in target rootfs
/home/ebrandt/Downloads/Linux_for_Tegra/nv_tegra/nv-apply-debs.sh
Root file system directory is /home/ebrandt/Downloads/Linux_for_Tegra/rootfs
Copying public debian packages to rootfs
Start L4T BSP package installation
QEMU binary is not available, looking for QEMU from host system
Found /usr/bin/qemu-aarch64-static
Installing QEMU binary in rootfs
~/Downloads/Linux_for_Tegra/rootfs ~/Downloads/Linux_for_Tegra
Installing BSP Debian packages in /home/ebrandt/Downloads/Linux_for_Tegra/rootfs
Selecting previously unselected package nvidia-l4t-core.
(Reading database ... 142475 files and directories currently installed.)
Preparing to unpack .../nvidia-l4t-core_32.6.1-20210726122859_arm64.deb ...
Pre-installing... skip compatibility checking.
Unpacking nvidia-l4t-core (32.6.1-20210726122859) ...
Setting up nvidia-l4t-core (32.6.1-20210726122859) ...
Selecting previously unselected package jetson-gpio-common.
(Reading database ... 142523 files and directories currently installed.)
Preparing to unpack .../jetson-gpio-common_2.0.17_arm64.deb ...
Unpacking jetson-gpio-common (2.0.17) ...
Selecting previously unselected package python3-jetson-gpio.
Preparing to unpack .../python3-jetson-gpio_2.0.17_arm64.deb ...
Unpacking python3-jetson-gpio (2.0.17) ...
Selecting previously unselected package python-jetson-gpio.
Preparing to unpack .../python-jetson-gpio_2.0.17_arm64.deb ...
Unpacking python-jetson-gpio (2.0.17) ...
Selecting previously unselected package nvidia-l4t-3d-core.
Preparing to unpack .../nvidia-l4t-3d-core_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-3d-core (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-apt-source.
Preparing to unpack .../nvidia-l4t-apt-source_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-apt-source (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-camera.
Preparing to unpack .../nvidia-l4t-camera_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-camera (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-configs.
Preparing to unpack .../nvidia-l4t-configs_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-configs (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-cuda.
Preparing to unpack .../nvidia-l4t-cuda_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-cuda (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-firmware.
Preparing to unpack .../nvidia-l4t-firmware_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-firmware (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-gputools.
Preparing to unpack .../nvidia-l4t-gputools_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-gputools (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-graphics-demos.
Preparing to unpack .../nvidia-l4t-graphics-demos_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-graphics-demos (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-gstreamer.
Preparing to unpack .../nvidia-l4t-gstreamer_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-gstreamer (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-init.
Preparing to unpack .../nvidia-l4t-init_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-init (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-initrd.
Preparing to unpack .../nvidia-l4t-initrd_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-initrd (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-jetson-io.
Preparing to unpack .../nvidia-l4t-jetson-io_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-jetson-io (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-libvulkan.
Preparing to unpack .../nvidia-l4t-libvulkan_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-libvulkan (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-multimedia.
Preparing to unpack .../nvidia-l4t-multimedia_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-multimedia (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-multimedia-utils.
Preparing to unpack .../nvidia-l4t-multimedia-utils_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-multimedia-utils (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-oem-config.
Preparing to unpack .../nvidia-l4t-oem-config_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-oem-config (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-tools.
Preparing to unpack .../nvidia-l4t-tools_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-tools (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-wayland.
Preparing to unpack .../nvidia-l4t-wayland_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-wayland (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-weston.
Preparing to unpack .../nvidia-l4t-weston_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-weston (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-x11.
Preparing to unpack .../nvidia-l4t-x11_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-x11 (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-xusb-firmware.
Preparing to unpack .../nvidia-l4t-xusb-firmware_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-xusb-firmware (32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-kernel.
Preparing to unpack .../nvidia-l4t-kernel_4.9.253-tegra-32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-kernel-dtbs.
Preparing to unpack .../nvidia-l4t-kernel-dtbs_4.9.253-tegra-32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-kernel-dtbs (4.9.253-tegra-32.6.1-20210726122859) ...
Selecting previously unselected package nvidia-l4t-kernel-headers.
Preparing to unpack .../nvidia-l4t-kernel-headers_4.9.253-tegra-32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-kernel-headers (4.9.253-tegra-32.6.1-20210726122859) ...
dpkg: error processing archive /opt/nvidia/l4t-packages/kernel/nvidia-l4t-kernel-headers_4.9.253-tegra-32.6.1-20210726122859_arm64.deb (--install):
corrupted filesystem tarfile - corrupted package archive
dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
Selecting previously unselected package nvidia-l4t-bootloader.
Preparing to unpack .../nvidia-l4t-bootloader_32.6.1-20210726122859_arm64.deb ...
Unpacking nvidia-l4t-bootloader (32.6.1-20210726122859) ...
Setting up jetson-gpio-common (2.0.17) ...
Setting up python3-jetson-gpio (2.0.17) ...
Setting up python-jetson-gpio (2.0.17) ...
Setting up nvidia-l4t-apt-source (32.6.1-20210726122859) ...
Pre-installing... skip changing source list.
Setting up nvidia-l4t-configs (32.6.1-20210726122859) ...
Setting up nvidia-l4t-firmware (32.6.1-20210726122859) ...
Setting up nvidia-l4t-gputools (32.6.1-20210726122859) ...
Setting up nvidia-l4t-init (32.6.1-20210726122859) ...
Setting up nvidia-l4t-libvulkan (32.6.1-20210726122859) ...
Setting up nvidia-l4t-multimedia-utils (32.6.1-20210726122859) ...
Setting up nvidia-l4t-oem-config (32.6.1-20210726122859) ...
Setting up nvidia-l4t-tools (32.6.1-20210726122859) ...
Setting up nvidia-l4t-wayland (32.6.1-20210726122859) ...
Setting up nvidia-l4t-weston (32.6.1-20210726122859) ...
Setting up nvidia-l4t-x11 (32.6.1-20210726122859) ...
Setting up nvidia-l4t-xusb-firmware (32.6.1-20210726122859) ...
Pre-installing xusb firmware package, skip flashing
Setting up nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20210726122859) ...
Using the existing boot entry 'primary'
Pre-installing kernel package, skip flashing
Setting up nvidia-l4t-kernel-dtbs (4.9.253-tegra-32.6.1-20210726122859) ...
Pre-installing kernel-dtbs package, skip flashing
Setting up nvidia-l4t-bootloader (32.6.1-20210726122859) ...
Pre-installing bootloader package, skip flashing
Setting up nvidia-l4t-3d-core (32.6.1-20210726122859) ...
Setting up nvidia-l4t-cuda (32.6.1-20210726122859) ...
Setting up nvidia-l4t-graphics-demos (32.6.1-20210726122859) ...
Setting up nvidia-l4t-initrd (32.6.1-20210726122859) ...
Pre-installing initrd package, skip flashing
Setting up nvidia-l4t-jetson-io (32.6.1-20210726122859) ...
Setting up nvidia-l4t-multimedia (32.6.1-20210726122859) ...
Setting up nvidia-l4t-camera (32.6.1-20210726122859) ...
Setting up nvidia-l4t-gstreamer (32.6.1-20210726122859) ...
Processing triggers for nvidia-l4t-kernel (4.9.253-tegra-32.6.1-20210726122859) ...
Processing triggers for libc-bin (2.27-3ubuntu1.4) ...
Errors were encountered while processing:
ebrandt@ubu1804:~/Downloads/Linux_for_Tegra$ ls
apply_binaries.sh nv_tools
bootloader p2597-0000+p3310-1000-as-p3489-0888.conf
build_l4t_bup.sh p2597-0000+p3310-1000.conf
clara-agx-xavier-devkit.conf p2597-0000+p3489-0000-ucm1.conf
e3900-0000+p2888-0004-b00.conf p2597-0000+p3489-0000-ucm2.conf
flash.sh p2597-0000+p3489-0888.conf
jetson-agx-xavier-devkit.conf p2771-0000.conf.common
jetson-agx-xavier-ind-noecc.conf p2771-0000-dsi-hdmi-dp.conf
jetson-agx-xavier-industrial.conf p2822-0000+p2888-0001.conf
jetson-agx-xavier-industrial-mxn.conf p2822-0000+p2888-0004.conf
jetson-tx2-4GB.conf p2822-0000+p2888-0008.conf
jetson-tx2-as-4GB.conf p2822-0000+p2888-0008-maxn.conf
jetson-tx2.conf p2822-0000+p2888-0008-noecc.conf
jetson-tx2-devkit-4gb.conf p2822+p2888-0001-as-p3668-0001.conf
jetson-tx2-devkit.conf p2972-0000.conf.common
jetson-tx2-devkit-tx2i.conf p2972-0000-devkit-maxn.conf
jetson-tx2i.conf p2972-0000-devkit-slvs-ec.conf
jetson-xavier-as-8gb.conf p2972-as-galen-8gb.conf
jetson-xavier-as-xavier-nx.conf p2972.conf
jetson-xavier.conf p3449-0000+p3668-0000-qspi-sd.conf
jetson-xavier-maxn.conf p3449-0000+p3668-0001-qspi-emmc.conf
jetson-xavier-nx-devkit.conf p3509-0000+p3636-0001.conf
jetson-xavier-nx-devkit-emmc.conf p3509-0000+p3668-0000-qspi.conf
jetson-xavier-nx-devkit-qspi.conf p3509-0000+p3668-0000-qspi-sd.conf
jetson-xavier-nx-devkit-tx2-nx.conf p3509-0000+p3668-0001-qspi-emmc.conf
jetson-xavier-slvs-ec.conf p3636.conf.common
kernel p3668.conf.common
l4t_generate_soc_bup.sh README_Autoflash.txt
l4t_sign_image.sh README_Massflash.txt
LICENSE.sce_t194 rootfs
nvautoflash.sh source
nvmassflashgen.sh source_sync.sh
nvsdkmanager_flash.sh tools
nv_tegra
ebrandt@ubu1804:~/Downloads/Linux_for_Tegra$ sudo ./flash.sh ${BOARD} mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 6.1
# Target Board Information:
# Name: jetson-xavier-nx-devkit-tx2-nx, Board Family: t186ref, SoC: Tegra 186,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
./tegraflash.py --chip 0x18 --applet "/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin" --skipuid --cmd "dump eeprom boardinfo cvm.bin"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0025 ] Generating RCM messages
[ 0.0046 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin 0 0
[ 0.0053 ] RCM 0 is saved as rcm_0.rcm
[ 0.0055 ] RCM 1 is saved as rcm_1.rcm
[ 0.0055 ] List of rcm files are saved in rcm_list.xml
[ 0.0056 ]
[ 0.0056 ] Signing RCM messages
[ 0.0078 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0078 ] Assuming zero filled SBK key
[ 0.0133 ] Copying signature to RCM mesages
[ 0.0152 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0162 ]
[ 0.0162 ] Boot Rom communication
[ 0.0180 ] tegrarcm_v2 --chip 0x18 0 --rcm rcm_list_signed.xml --skipuid
[ 0.0186 ] RCM version 0X180001
[ 0.0473 ] Boot Rom communication completed
[ 1.0541 ]
[ 2.0600 ] tegrarcm_v2 --isapplet
[ 2.0639 ] Applet version 01.00.0000
[ 2.0935 ]
[ 2.0985 ] Retrieving EEPROM data
[ 2.0988 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 2.1012 ] Applet version 01.00.0000
[ 2.1500 ] Saved platform info in /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/cvm.bin
[ 2.2225 ]
Board ID(3636) version(301) sku(0001) revision(D.0)
Copy /home/ebrandt/Downloads/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb to /home/ebrandt/Downloads/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb.rec
copying bctfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-memcfg-p3636-0001-a01.cfg)... done.
copying misc_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-misc-si-l4t.cfg)... done.
copying pinmux_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pinmux-p3636-0001-a00.cfg)... done.
copying pmic_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pmic-p3636-0001-a00.cfg)... done.
copying pmc_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-pad-p3636-0001-a00.cfg)... done.
copying prod_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-prod-p3636-0001-a00.cfg)... done.
copying scr_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/minimal_scr.cfg)... done.
copying scr_cold_boot_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/mobile_scr.cfg)... done.
copying bootrom_config(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/tegra186-mb1-bct-bootrom-p3636-0001-a00.cfg)... done.
copying dev_params(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/BCT/emmc.cfg)... done.
Existing bootloader(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
copying initrd(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign boot.img kernel
version 1.0.0
[ 0.0003 ] Generating signature
[ 0.0023 ] tegrasign_v3.py --getmode mode.txt --key
[ 0.0023 ] Assuming zero filled SBK key : not reading
[ 0.0023 ] sign_type : 0
[ 0.0023 ] header_magic: 414e4452
[ 0.0041 ] tegrahost_v2 --chip 0x18 --align 1_boot.img
[ 0.0046 ]
[ 0.0063 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_boot.img zerosbk
[ 0.0075 ]
[ 0.0352 ] tegrasign_v3.py --key --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[ 0.0353 ] Assuming zero filled SBK key : not reading
[ 0.0461 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[ 0.0472 ]
[ 0.0477 ] Signed file: /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x18: Don't need to do anything
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Making recovery ramdisk for recovery image...
Re-generating recovery ramdisk for recovery image...
~/Downloads/Linux_for_Tegra/bootloader/ramdisk_tmp ~/Downloads/Linux_for_Tegra/bootloader ~/Downloads/Linux_for_Tegra
30412 blocks
_BASE_KERNEL_VERSION=4.9.253-tegra
~/Downloads/Linux_for_Tegra/bootloader/ramdisk_tmp/lib ~/Downloads/Linux_for_Tegra/bootloader/ramdisk_tmp ~/Downloads/Linux_for_Tegra/bootloader ~/Downloads/Linux_for_Tegra
66117 blocks
Making Recovery image...
copying recdtbfile(/home/ebrandt/Downloads/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb.rec)... done.
20+0 records in
20+0 records out
20 bytes copied, 0.000524978 s, 38.1 kB/s
Existing sosfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/mb1_recovery_prod.bin) reused.
copying tegraboot(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/nvtboot.bin)... done.
Existing cpu_bootloader(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/nvtboot_cpu.bin) reused.
Existing mb2blfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery.bin) reused.
Existing mtspreboot(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/preboot_d15_prod_cr.bin) reused.
Existing mts(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/mce_mts_d15_prod_cr.bin) reused.
Existing mb1file(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/mb1_prod.bin) reused.
Existing bpffile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/bpmp.bin) reused.
copying bpfdtbfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/tegra186-bpmp-p3636-0001-a00-00.dtb)... done.
Existing scefile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing spefile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/spe.bin) reused.
copying wb0boot(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/warmboot.bin)... done.
Existing tosfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/tos-trusty.img) reused.
Existing eksfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/eks.img) reused.
copying dtbfile(/home/ebrandt/Downloads/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb)... done.
Copying nv_boot_control.conf to rootfs
/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/tegraflash.py --chip 0x18 --key --cmd sign kernel_tegra186-p3636-0001-p3509-0000-a01.dtb kernel_dtb
version 1.0.0
[ 0.0004 ] Generating signature
[ 0.0023 ] sign_type : 811674928
[ 0.0023 ] header_magic: d00dfeed
[ 0.0040 ] tegrahost_v2 --chip 0x18 --align 1_kernel_tegra186-p3636-0001-p3509-0000-a01.dtb
[ 0.0045 ]
[ 0.0062 ] tegrahost_v2 --chip 0x18 0 --appendsigheader 1_kernel_tegra186-p3636-0001-p3509-0000-a01.dtb zerosbk
[ 0.0070 ]
[ 0.0096 ] tegrasign_v3.py --key --list 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[ 0.0097 ] Assuming zero filled SBK key : not reading
[ 0.0153 ] tegrahost_v2 --chip 0x18 0 --updatesigheader 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt 1_kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.hash zerosbk
[ 0.0161 ]
[ 0.0164 ] Signed file: /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/temp_user_dir/kernel_tegra186-p3636-0001-p3509-0000-a01_sigheader.dtb.encrypt
done.
populating kernel to rootfs... done.
populating initrd to rootfs... done.
populating kernel_tegra186-p3636-0001-p3509-0000-a01.dtb to rootfs... done.
Making system.img...
populating rootfs from /home/ebrandt/Downloads/Linux_for_Tegra/rootfs ... populating /boot/extlinux/extlinux.conf ... done.
Sync'ing system.img ... done.
Converting RAW image to Sparse image... done.
system.img built successfully.
Existing tbcfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/cboot.bin) reused.
copying tbcdtbfile(/home/ebrandt/Downloads/Linux_for_Tegra/kernel/dtb/tegra186-p3636-0001-p3509-0000-a01.dtb)... done.
copying cfgfile(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/t186ref/cfg/flash_l4t_t186.xml) to flash.xml... done.
Existing flasher(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/nvtboot_recovery_cpu.bin) reused.
Existing flashapp(/home/ebrandt/Downloads/Linux_for_Tegra/bootloader/tegraflash.py) reused.
./tegraflash.py --bl nvtboot_recovery_cpu.bin --sdram_config tegra186-mb1-bct-memcfg-p3636-0001-a01.cfg --odmdata 0x2090000 --applet mb1_recovery_prod.bin --cmd "flash; reboot" --cfg flash.xml --chip 0x18 --misc_config tegra186-mb1-bct-misc-si-l4t.cfg --pinmux_config tegra186-mb1-bct-pinmux-p3636-0001-a00.cfg --pmic_config tegra186-mb1-bct-pmic-p3636-0001-a00.cfg --pmc_config tegra186-mb1-bct-pad-p3636-0001-a00.cfg --prod_config tegra186-mb1-bct-prod-p3636-0001-a00.cfg --scr_config minimal_scr.cfg --scr_cold_boot_config mobile_scr.cfg --br_cmd_config tegra186-mb1-bct-bootrom-p3636-0001-a00.cfg --dev_params emmc.cfg --bins "mb2_bootloader nvtboot_recovery.bin; mts_preboot preboot_d15_prod_cr.bin; mts_bootpack mce_mts_d15_prod_cr.bin; bpmp_fw bpmp.bin; bpmp_fw_dtb tegra186-bpmp-p3636-0001-a00-00.dtb; tlk tos-trusty.img; eks eks.img; bootloader_dtb tegra186-p3636-0001-p3509-0000-a01.dtb"
saving flash command in /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ebrandt/Downloads/Linux_for_Tegra/bootloader/flash_win.bat
*** Flashing target device started. ***
version 1.0.0
[ 0.0075 ] tegrasign_v3.py --getmode mode.txt --key None
[ 0.0075 ] Assuming zero filled SBK key
[ 0.0020 ] Generating RCM messages
[ 0.0220 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x18 0 --download rcm mb1_recovery_prod.bin 0 0
[ 0.0227 ] RCM 0 is saved as rcm_0.rcm
[ 0.0230 ] RCM 1 is saved as rcm_1.rcm
[ 0.0230 ] List of rcm files are saved in rcm_list.xml
[ 0.0230 ]
[ 0.0230 ] Signing RCM messages
[ 0.0305 ] tegrasign_v3.py --key None --list rcm_list.xml --pubkeyhash pub_key.key
[ 0.0306 ] Assuming zero filled SBK key
[ 0.0378 ] Copying signature to RCM mesages
[ 0.0396 ] tegrarcm_v2 --chip 0x18 0 --updatesig rcm_list_signed.xml
[ 0.0403 ]
[ 0.0404 ] Parsing partition layout
[ 0.0542 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0574 ]
[ 0.0575 ] Using default ramcode: 0
[ 0.0575 ] Disable BPMP dtb trim, using default dtb
[ 0.0575 ]
[ 0.0575 ] Creating list of images to be signed
[ 0.0690 ] tegrahost_v2 --chip 0x18 0 --partitionlayout flash.xml.bin --list images_list.xml zerosbk
... clipped to fit in forum msg limit...
[ 245.4729 ]
[ 245.4772 ] tegradevflash_v2 --write BCT br_bct_BR.bct
[ 245.4798 ] Bootloader version 01.00.0000
[ 245.5092 ] Writing partition BCT with br_bct_BR.bct
[ 245.5101 ] [................................................] 100%
[ 245.5190 ]
[ 245.5265 ] tegradevflash_v2 --write MB1_BCT mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 245.5290 ] Bootloader version 01.00.0000
[ 245.5571 ] Writing partition MB1_BCT with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 245.5586 ] [................................................] 100%
[ 245.5678 ]
[ 245.5720 ] tegradevflash_v2 --write MB1_BCT_b mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 245.5746 ] Bootloader version 01.00.0000
[ 245.6060 ] Writing partition MB1_BCT_b with mb1_cold_boot_bct_MB1_sigheader.bct.encrypt
[ 245.6064 ] [................................................] 100%
[ 245.6169 ]
[ 245.6169 ] Flashing completed
[ 245.6169 ] Coldbooting the device
[ 245.6187 ] tegradevflash_v2 --reboot coldboot
[ 245.6193 ] Bootloader version 01.00.0000
[ 245.6533 ]
*** The target t186ref has been flashed successfully. ***
Reset the board to boot from internal eMMC.
