Issue with Serial_CAN_FD Library
Hi guys,
I’m trying to integrate an Arduino Nano with a Kelly motor controller which uses CAN bus to transmit data.
I’ve purchased the Seed Studio Serial CAN module but having an issue with the way the code is reading the ID from the controller. I think that the library is designed for the smaller CAN ID of 11 bits rather than the 29 bit ID my controller is sending. Has anyone made any similar changes to it?
I’ve got little experience editing Arduino libraries so any pointers would be much appreciated! I’ve pasted the library below:
#include <stdio.h>
#include “Serial_CAN_FD.h”
extern void uart_init(unsigned long baudrate);
extern void uart_write(unsigned char c);
extern unsigned char uart_read();
extern int uart_available();
int dtaLen = 0;
unsigned char dtaCan[100];
unsigned long char2long(unsigned char *str)
unsigned long num = 0;
memcpy((unsigned char *)(&num), str, 4);
return num;
void long2char(unsigned long num, unsigned char str)
memcpy(str, (unsigned char
)(&num), 4);
unsigned int CrcCalculate(unsigned char Byte, unsigned int _CRC)
unsigned char Carry;
int Bit_Index;
_CRC = _CRC ^ (Byte & 0xFF);
for (Bit_Index = 0; Bit_Index < 8; Bit_Index++)
Carry = _CRC & 0x0001;
_CRC = _CRC >> 1;
if (Carry)
_CRC = _CRC ^ 0xA001;
return _CRC;
unsigned int calCRC(unsigned char *str)
unsigned int __crc = 0xffff;
int i=0;
for(i=0; i < str[1]; i++)
    __crc = CrcCalculate(str[i+2], __crc);
return __crc;
unsigned char checkCRC(unsigned char *str)
unsigned int __crc = calCRC(str);
unsigned int __crc0 = str[3+str[1]];
__crc0 <<= 8;
__crc0 |= str[2+str[1]];
return (__crc == __crc0);
return 0;
void can_send(unsigned long id, unsigned char ext, unsigned char rtr, unsigned char fdf, unsigned char len, unsigned char *dta)
unsigned char str[80];
str[0] = 0xAA;
str[1] = len+9;
str[2] = 0x01;
long2char(id, &str[3]);
str[7] = ext;
str[8] = rtr;
str[9] = fdf;
str[10] = len;
for(int i=0; i<len; i++)
str[11+i] = dta[i];
unsigned int crc = calCRC(str);
str[11+len] = crc & 0xff;
str[12+len] = (crc>>8) & 0xff;
for(int i=0; i<(13+len); i++)
    uart_write(str[i]);
void can_speed_fd(unsigned long speed_20, unsigned long speed_fd)
str[0] = 0xAA;
str[1] = 0x09;
str[2] = 0x02;
long2char(speed_20, &str[3]);
long2char(speed_fd, &str[7]);
str[str[1]+2] = crc & 0xff;
str[str[1]+3] = (crc>>8) & 0xff;
for(int i=0; i<(4+str[1]); i++)
    uart_write(str[i]);
void can_speed_20(unsigned long speed_20)
can_speed_fd(speed_20, 4000000);
void strProcess(int num)
if(dtaLen >= num)
unsigned char __str[500];
memcpy(__str, dtaCan, dtaLen);
memcpy(dtaCan, &__str[num], dtaLen-num);
dtaLen = dtaLen-num;
void checkData()
int __len = 0;
unsigned char __dta[100];
int i=0;
for(i=0; i<dtaLen; i++)
    if(dtaCan[0] != 0xAA)
        strProcess(1);
    else break;
if(dtaLen>2)
    if(dtaLen >= (dtaCan[1]+4))
        __len = dtaLen;
        memcpy(__dta, dtaCan, __len);
        strProcess(__len);
        dtaProcess(__len, __dta);
void serialProcess()
while(uart_available())
dtaCan[dtaLen++] = uart_read();
//Serial.write(dtaCan[dtaLen-1]);
void dtaProcess(int len, unsigned char *dta)
int i=0;
unsigned long tmp = 0;
int __crc = checkCRC(dta);
if(__crc)
    Serial.println("get dta crc ok");
int read_can(unsigned long *id, unsigned char *ext, unsigned char *rtr, unsigned char *fdf, unsigned char *len, unsigned char *dta)
serialProcess();
if(dtaLen == 0)return 0;
int __len = 0;
int i=0;
        strProcess(1);
    else break;
if(dtaLen>2)
        __len = dtaLen;
        strProcess(__len);
        int __crc = checkCRC(__dta);
        if(__crc)
            *id = char2long(&__dta[3]);
            *ext = __dta[7];
            *rtr = __dta[8];
            *fdf = __dta[9];
            *len = __dta[10];
            for(int i=0; i<*len; i++)
                dta[i] = __dta[11+i];
            return 1;
        else return 0;
return 0;
void set_mask_filt(unsigned char num, unsigned char ext, unsigned long mask, unsigned long filt)
if(num > 3)return;
unsigned char str[15];
str[0] = 0xAA;
str[1] = 11;
str[2] = 0x03+num;
str[3] = 1;
str[4] = ext;
long2char(mask, &str[5]);
long2char(filt, &str[9]);
str[13] = crc & 0xff;
str[14] = (crc>>8) & 0xff;
for(int i=0; i<15; i++)
    uart_write(str[i]);
void set_baudrate(unsigned long __baud)
str[0] = 0xAA;
str[1] = 5;
str[2] = 7;
long2char(__baud, &str[3]);
str[7] = crc & 0xff;
str[8] = (crc>>8) & 0xff;
for(int i=0; i<9; i++)
    uart_write(str[i]);
delay(10);
uart_init(__baud);
// END FILE
