installation of the offline speech recognition
I would like to ask for your help regarding the installation of the offline speech recognition. How can I install/use the PocketSphinx - I tried to install the PocketSphinx and its dependencies: pip install pocketsphinx webrtcvad requests monotonic - I run the python examples and there was any exception unfortunately.
for example:
respeaker_python_library/examples/offline_voice_assistant.py, especially card detection (microphone.py):
[attachment=2]20180521_101654.png[/attachment]
Here is my card:
[attachment=1]20180521_101509.png[/attachment]
and here is a pyaudio code which can shows the details about the devices:
python -c “import pyaudio;audio=pyaudio.PyAudio();print([audio.get_device_info_by_index(i) for i in range(audio.get_device_count())])”
On the response I can see same problem as before (offline_voice_assistant.py):
[attachment=0]20180521_103422.png[/attachment]
thank you in advanced!
Hi there:
We have successfully run snowboy on respeaker V2. We will study it for you and reply you next week.
Hi there:
You can modify the file as follows(/usr/share/alsa/alsa.conf):[code]#
ALSA library configuration file
pre-load the configuration files
@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
“/alsa.conf.d/”
“/etc/asound.conf”
“~/.asoundrc”
errors false
load card-specific configuration files (on request)
cards.@hooks [
func load
files [
@func concat
strings [
{ @func datadir }
“/cards/aliases.conf”
func load_for_all_cards
files [
@func concat
strings [
{ @func datadir }
“/cards/”
{ @func private_string }
“.conf”
errors false
defaults
show all name hints also for definitions without hint {} section
defaults.namehint.showall on
show just basic name hints
defaults.namehint.basic on
show extended name hints
defaults.namehint.extended on
defaults.ctl.card 0
defaults.pcm.card 0
defaults.pcm.device 0
defaults.pcm.subdevice -1
defaults.pcm.nonblock 1
defaults.pcm.compat 0
defaults.pcm.minperiodtime 5000 # in us
defaults.pcm.ipc_key 5678293
defaults.pcm.ipc_gid audio
defaults.pcm.ipc_perm 0660
defaults.pcm.dmix.max_periods 0
defaults.pcm.dmix.rate 48000
defaults.pcm.dmix.format “unchanged”
defaults.pcm.dmix.card defaults.pcm.card
defaults.pcm.dmix.device defaults.pcm.device
defaults.pcm.dsnoop.card defaults.pcm.card
defaults.pcm.dsnoop.device defaults.pcm.device
defaults.pcm.front.card defaults.pcm.card
defaults.pcm.front.device defaults.pcm.device
defaults.pcm.rear.card defaults.pcm.card
defaults.pcm.rear.device defaults.pcm.device
defaults.pcm.center_lfe.card defaults.pcm.card
defaults.pcm.center_lfe.device defaults.pcm.device
defaults.pcm.side.card defaults.pcm.card
defaults.pcm.side.device defaults.pcm.device
defaults.pcm.surround21.card defaults.pcm.card
defaults.pcm.surround21.device defaults.pcm.device
defaults.pcm.surround40.card defaults.pcm.card
defaults.pcm.surround40.device defaults.pcm.device
defaults.pcm.surround41.card defaults.pcm.card
defaults.pcm.surround41.device defaults.pcm.device
defaults.pcm.surround50.card defaults.pcm.card
defaults.pcm.surround50.device defaults.pcm.device
defaults.pcm.surround51.card defaults.pcm.card
defaults.pcm.surround51.device defaults.pcm.device
defaults.pcm.surround71.card defaults.pcm.card
defaults.pcm.surround71.device defaults.pcm.device
defaults.pcm.iec958.card defaults.pcm.card
defaults.pcm.iec958.device defaults.pcm.device
defaults.pcm.modem.card defaults.pcm.card
defaults.pcm.modem.device defaults.pcm.device
truncate files via file or tee PCM
defaults.pcm.file_format “raw”
defaults.pcm.file_truncate true
defaults.rawmidi.card 0
defaults.rawmidi.device 0
defaults.rawmidi.subdevice -1
defaults.hwdep.card 0
defaults.hwdep.device 0
defaults.timer.class 2
defaults.timer.sclass 0
defaults.timer.card 0
defaults.timer.device 0
defaults.timer.subdevice 0
PCM interface
redirect to load-on-demand extended pcm definitions
pcm.cards cards.pcm
pcm.default cards.pcm.default
pcm.sysdefault cards.pcm.default
#pcm.front cards.pcm.front
#pcm.rear cards.pcm.rear
#pcm.center_lfe cards.pcm.center_lfe
#pcm.side cards.pcm.side
#pcm.surround21 cards.pcm.surround21
#pcm.surround40 cards.pcm.surround40
#pcm.surround41 cards.pcm.surround41
#pcm.surround50 cards.pcm.surround50
#pcm.surround51 cards.pcm.surround51
#pcm.surround71 cards.pcm.surround71
#pcm.iec958 cards.pcm.iec958
#pcm.spdif iec958
#pcm.hdmi cards.pcm.hdmi
#pcm.dmix cards.pcm.dmix
#pcm.dsnoop cards.pcm.dsnoop
#pcm.modem cards.pcm.modem
#pcm.phoneline cards.pcm.phoneline
pcm.hw {
@args [ CARD DEV SUBDEV ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_PCM_CARD
ALSA_CARD
default {
@func refer
name defaults.pcm.card
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_PCM_DEVICE
default {
@func refer
name defaults.pcm.device
@args.SUBDEV {
type integer
default {
@func refer
name defaults.pcm.subdevice
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
show {
@func refer
name defaults.namehint.extended
description “Direct hardware device without any conversions”
pcm.plughw {
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_PCM_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_PCM_DEVICE
default {
@func refer
@args.SUBDEV {
type integer
default {
@func refer
type plug
slave.pcm {
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
show {
@func refer
description “Hardware device with all software conversions”
pcm.plug {
@args [ SLAVE ]
@args.SLAVE {
type string
type plug
slave.pcm $SLAVE
pcm.shm {
@args [ SOCKET PCM ]
@args.SOCKET {
type string
@args.PCM {
type string
type shm
server $SOCKET
pcm $PCM
pcm.tee {
@args [ SLAVE FILE FORMAT ]
@args.SLAVE {
type string
@args.FILE {
type string
@args.FORMAT {
type string
default {
@func refer
name defaults.pcm.file_format
type file
slave.pcm $SLAVE
file $FILE
format $FORMAT
truncate {
@func refer
name defaults.pcm.file_truncate
pcm.file {
@args [ FILE FORMAT ]
@args.FILE {
type string
@args.FORMAT {
type string
default {
@func refer
type file
slave.pcm null
file $FILE
format $FORMAT
truncate {
@func refer
pcm.null {
type null
hint {
show {
@func refer
name defaults.namehint.basic
description “Discard all samples (playback) or generate zero samples (capture)”
Control interface
ctl.sysdefault {
type hw
card {
@func getenv
vars [
ALSA_CTL_CARD
ALSA_CARD
default {
@func refer
name defaults.ctl.card
hint.description “Default control device”
ctl.default ctl.sysdefault
ctl.hw {
@args [ CARD ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_CTL_CARD
ALSA_CARD
default {
@func refer
type hw
card $CARD
hint.description “Direct control device”
ctl.shm {
@args [ SOCKET CTL ]
@args.SOCKET {
type string
@args.CTL {
type string
type shm
server $SOCKET
ctl $CTL
RawMidi interface
rawmidi.default {
type hw
card {
@func getenv
vars [
ALSA_RAWMIDI_CARD
ALSA_CARD
default {
@func refer
name defaults.rawmidi.card
device {
@func igetenv
vars [
ALSA_RAWMIDI_DEVICE
default {
@func refer
name defaults.rawmidi.device
hint.description “Default raw MIDI device”
rawmidi.hw {
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_RAWMIDI_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_RAWMIDI_DEVICE
default {
@func refer
@args.SUBDEV {
type integer
default -1
type hw
card $CARD
device $DEV
subdevice $SUBDEV
hint {
description “Direct rawmidi driver device”
device $DEV
rawmidi.virtual {
@args [ MERGE ]
@args.MERGE {
type string
default 1
type virtual
merge $MERGE
Sequencer interface
seq.default {
type hw
hint.description “Default sequencer device”
seq.hw {
type hw
HwDep interface
hwdep.default {
type hw
card {
@func getenv
vars [
ALSA_HWDEP_CARD
ALSA_CARD
default {
@func refer
name defaults.hwdep.card
device {
@func igetenv
vars [
ALSA_HWDEP_DEVICE
default {
@func refer
name defaults.hwdep.device
hint.description “Default hardware dependent device”
hwdep.hw {
@args [ CARD DEV ]
@args.CARD {
type string
default {
@func getenv
vars [
ALSA_HWDEP_CARD
ALSA_CARD
default {
@func refer
@args.DEV {
type integer
default {
@func igetenv
vars [
ALSA_HWDEP_DEVICE
default {
@func refer
type hw
card $CARD
device $DEV
hint {
description “Direct hardware dependent device”
device $DEV
Timer interface
timer_query.default {
type hw
timer_query.hw {
type hw
timer.default {
type hw
class {
@func refer
name defaults.timer.class
sclass {
@func refer
name defaults.timer.sclass
card {
@func refer
name defaults.timer.card
device {
@func refer
name defaults.timer.device
subdevice {
@func refer
name defaults.timer.subdevice
hint.description “Default timer device”
timer.hw {
@args [ CLASS SCLASS CARD DEV SUBDEV ]
@args.CLASS {
type integer
default {
@func refer
@args.SCLASS {
type integer
default {
@func refer
@args.CARD {
type string
default {
@func refer
@args.DEV {
type integer
default {
@func refer
@args.SUBDEV {
type integer
default {
@func refer
type hw
class $CLASS
sclass $SCLASS
card $CARD
device $DEV
subdevice $SUBDEV
hint {
description “Direct timer device”
device $DEV
[/code]
Hi, I tried it and ok, there isn’t any error message, but the offline recognition does not work, there is no “input waiting”, just this:
[attachment=0]20180602_093124.png[/attachment]
If I say “Snowboy”, there won’t any reaction.
Hi there:
your log messages show: cannot connect to server scoket err …,It means there is something wrong with your network communication. Please check if your communication is normal.
you are right, but but there is not any instruction about offline sp. rec. settings on respeaker’s wiki.
Please describe how we can set it.
Hi there, We come out the wiki with bing and pocketspinx from <LINK_TEXT text=“http://wiki.seeedstudio.com/ReSpeaker_C … -with-bing”>http://wiki.seeedstudio.com/ReSpeaker_Core_v2.0/#play-with-bing</LINK_TEXT>. please refer to the <LINK_TEXT text=“https://github.com/respeaker/respeaker_ … sistant.py”>https://github.com/respeaker/respeaker_python_library/blob/master/examples/offline_voice_assistant.py</LINK_TEXT> for the offline voice test. thanks.
Seeed techsupport team
Bill
Hi Bill, I know the second url, it is cloned to Respeaker and I can run it, there is no any errors and there is not any interactivity.
I say that “respeaker” and the respeaker does nothing.
Dear Customer,
I tested offline_voice_assistant.py and it responses as wakeup. here is the screen. thanks.
Bill
I just ran into a similar problem with the offline STT.
No errors when I installed everything. Other demos work, the Alexa demos all work.
Here is the output when I try and run it…
respeaker@v2:~$ python respeaker_python_library/examples/offline_voice_assistant.py
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.front
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround21
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround40
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround41
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround50
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround51
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.surround71
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.iec958
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.hdmi
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:1052:(snd_pcm_dmix_open) unable to open slave
Here is the output of the ALSA diagnostics from the above thread.
[{‘defaultSampleRate’: 48000.0, ‘defaultLowOutputLatency’: 0.005333333333333333, ‘defaultLowInputLatency’: -1.0, ‘maxInputChannels’: 0L, ‘structVersion’: 2L, ‘hostApi’: 0L, ‘index’: 0, ‘defaultHighOutputLatency’: 0.032, ‘maxOutputChannels’: 2L, ‘name’: u’seeed-8mic-voicecard: - (hw:0,1)’, ‘defaultHighInputLatency’: -1.0}, {‘defaultSampleRate’: 44100.0, ‘defaultLowOutputLatency’: 0.00873015873015873, ‘defaultLowInputLatency’: 0.008707482993197279, ‘maxInputChannels’: 32L, ‘structVersion’: 2L, ‘hostApi’: 0L, ‘index’: 1, ‘defaultHighOutputLatency’: 0.034829931972789115, ‘maxOutputChannels’: 32L, ‘name’: u’default’, ‘defaultHighInputLatency’: 0.034829931972789115}]
Hi, please ignore the errors, Let’s say ReSpeaker to wakeup and then say alexa. You can see terminal as below. thanks.
Wake up
00000000000000000000000000000000000000000001111+00000000-1111+1111111111111111111111100000000-0000000000000001111+00000000-00000000000000000000000001111+11111111111111111100000000-Recognized alexa alexa
Bill
