I am having trouble with the Jupyter Notebook when I try to follow Tutorial-of-AI-Kit-with-Raspberry-Pi-From-Zero-to-Hero/articles/Chapter 5 - Developing and Deploying a Custom Model
I am proceeding with Jupyter Notebook by referring to Tutorial-of-AI-Kit-with-Raspberry-Pi-From-Zero-to-Hero/articles/Chapter 5 - Developing and Deploying a Custom Model.--------------------------------------------------------------------------------------------- !pip install /home/pi/Downloads/hailo_dataflow_compiler-3.28.0-py3-none-linux_x86_64.whl
Define the model name and onnx model path
onnx_model_name = “yolov11n”
onnx_path = “/home/pi/best20241109.onnx”
AI kit chip is hailo8l, so we choose hailo8l as hardware arch
chosen_hw_arch = “hailo8”
runner = ClientRunner(hw_arch=chosen_hw_arch)
hn, npz = runner.translate_onnx_model(
onnx_path,
onnx_model_name,
start_node_names=[“/model.0/conv/Conv”], # the name of input node
end_node_names=[“/model.23/cv2.0/cv2.0.2/Conv”, “/model.23/cv3.0/cv3.0.2/Conv”,
“/model.23/cv2.1/cv2.1.2/Conv”, “/model.23/cv3.1/cv3.1.2/Conv”,
“/model.23/cv2.2/cv2.2.2/Conv”, “/model.23/cv3.2/cv3.2.2/Conv”], # the name of output node
net_input_shapes={“/model.0/conv/Conv”: [1, 3, 640, 640]}, # input shape
Save to har model
hailo_model_har_name = f"/home/pi/{onnx_model_name}_hailo_model.har"
runner.save_har(hailo_model_har_name)
Use hailo command to parse the model *yolov11n.svg 파일생성
!hailo visualizer /home/pi/{onnx_model_name}_hailo_model.har
#최적화
General imports used throughout the tutorial
file operations
import json
import os
import numpy as np
import tensorflow as tf
from IPython.display import SVG
from matplotlib import patches
from matplotlib import pyplot as plt
from PIL import Image
from tensorflow.python.eager.context import eager_mode
import the hailo sdk client relevant classes
from hailo_sdk_client import ClientRunner, InferenceContext
%matplotlib inline
IMAGES_TO_VISUALIZE = 5
#2
The folder of images
image_dir = ‘/home/pi/images’
image_files = [f for f in os.listdir(image_dir) if f.endswith((‘.png’, ‘.jpg’, ‘.jpeg’))]
Init the list
images =
Load every images
for image_file in image_files:
img_path = os.path.join(image_dir, image_file)
img = Image.open(img_path).convert(‘RGB’) # Transform to RGB format
img_array = np.array(img, dtype=object ) # Transform to NumPy format
images.append(img_array)
Transform images to NumPy array
images_array = np.array(images)
#3
Load our parsed HAR model
assert os.path.isfile(hailo_model_har_name), “Please provide valid path for HAR file”
runner = ClientRunner(har=hailo_model_har_name, hw_arch=chosen_hw_arch)
By default it uses the hw_arch that is saved on the HAR. For overriding, use the hw_arch flag.
##4
Call Optimize to perform the optimization process
runner.optimize(images_array)
Save the result state to a Quantized HAR file
quantized_model_har_path = f"/home/pi/{onnx_model_name}_quantized_model.har"
runner.save_har(quantized_model_har_path)
I’ve been running the above codes one by one in the Jupyter notebook. # Save the result state to a Quantized HAR file
runner.save_har(quantized_model_har_path) When I run this code, the Jupyter notebook freezes. The cause is unknown.Please tell me how to solve the problem.
