I’m ordering my PCBs with smd components assembled. What is the best way to attach the XIAO ESP32s3 Plus after? Is it safe to use a hotplate with solder paste? Or will that damage the already placed components?
Any suggestions are much appreciated! ![]()
The datasheet for each of your board’s components should specify the times and temperatures allowed for reflowing of components.
it’ll be like “270c for 3 seconds max” or something like that.
the best way to connect a xiao would be adding a low profile female pin header to the board, and having that factory installed so you can switch to a different line of xiao’s if the mood takes you
