grove gsr on grovepi
I have purchased grove gsr and grovepi, wondering if there’s any sample code for grove gsr on grove pi ? any nodejs code or python code ? I have searched sample code for grove gsr on arduino only , it seems no sample code on grovepi ?
the gsr sensor is analog sensor. you can refer to <LINK_TEXT text=“https://github.com/DexterInd/GrovePi/bl … _switch.py”>https://github.com/DexterInd/GrovePi/blob/master/Software/Python/grove_tilt_switch.py</LINK_TEXT>. thanks.
Bill
Hi, the above is not grove gsr ? have you got any example of grove gsr on grovepi? any nodejs code ? python is fine … Thanks
HI Joe,
it is the same, coz both switch and gsr are anlog sensor. so you can use the same script to extract the analog reading. thanks.
best rgds
Bill
HI, Bill:
I have purchased a grovepi starter kit: <LINK_TEXT text=“https://www.dexterindustries.com/GroveP … arter-kit/”>https://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/grove-pi-starter-kit/</LINK_TEXT>,
So all I have to do is plugging grove gsr into grovepi and paste those codes ?
JOe
Hi Joe
Step 1. Follow Setting Software to configure the development environment. <LINK_TEXT text=“https://www.dexterindustries.com/GroveP … -software/”>https://www.dexterindustries.com/GrovePi/get-started-with-the-grovepi/setting-software/</LINK_TEXT>
Step 2. Git clone the Github repository.
cd ~
git clone https://github.com/DexterInd/GrovePi.git
Step 3. Excute below commands to use the grove_tilt_switch to meansure the distance.
cd ~/GrovePi/Software/Python
python grove_tilt_switch.py
thanks
Bill
Thanks Bill, will get a chance to try and update you soon, btw: I’d like to send those data to cloud for further machine learning analysis(feature selection/extraction for destress, normal, nurvous…), any similar case would be appreciated, it’s something like this: <LINK_TEXT text=“https://www.ibm.com/developerworks/libr … index.html”>https://www.ibm.com/developerworks/library/iot-cognitive-iot-app-machine-learning/index.html</LINK_TEXT>
Hi Joe,
please try <LINK_TEXT text=“https://project.seeedstudio.com/JiongSh … tem-d12772”>https://project.seeedstudio.com/JiongShi/csense-campus-environmental-surveillance-system-d12772</LINK_TEXT>. If you come out the project, please share it through https://project.seeedstudio.com/ thanks.
best rgds
Bill
Hi, Bill:
I have a another Seeeduino and grove gsr, any solution for collecting those gsr data on the cloud for training a machine learning model ? thanks
