HI,
I am a new user of Grove Base Hat for Raspberry Pi. I have to say that my knowledge of linux and python is limited.
<LINK_TEXT text=“http://wiki.seeedstudio.com/Grove_Base_ … stallation”>http://wiki.seeedstudio.com/Grove_Base_Hat_for_Raspberry_Pi/#installation</LINK_TEXT>
My raspberry Pi Zero BW is set with the last Raspbian img (2018-11-13-raspbian-stretch-full)
The one-click installation (curl -sL <LINK_TEXT text=“https://github.com/Seeed-Studio/grove.p … install.sh”>https://github.com/Seeed-Studio/grove.py/raw/master/install.sh</LINK_TEXT> | sudo bash -s -
) fail to install rpi-vl53l0x.
It seem that the C source code call by swig is not available at https://github.com/turmary/rpi-vl53l0x
Any advice?
Warning: apt-key output should not be parsed (stdout is not a terminal)
I2C interface enabled…
Hit:1 http://raspbian.raspberrypi.org/raspbian stretch InRelease
Hit:2 http://archive.raspberrypi.org/debian stretch InRelease
Hit:3 https://seeed-studio.github.io/pi_repo stretch InRelease
Reading package lists… Done
Building dependency tree
Reading state information… Done
All packages are up to date.
libmraa1 is already the newest version (1.9.0-git20181030-pi20181030).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
python-mraa is already the newest version (1.9.0-git20181030-pi20181030).
python-upm is already the newest version (1.6.0-git20180813-pi20180813).
python3-mraa is already the newest version (1.9.0-git20181030-pi20181030).
python3-upm is already the newest version (1.6.0-git20180813-pi20180813).
python-rpi.gpio is already the newest version (0.6.5~stretch-1).
python3-rpi.gpio is already the newest version (0.6.5~stretch-1).
libbma456 is already the newest version (1.0.0-1).
libbmi088 is already the newest version (0.0.2-1).
python-bme680 is already the newest version (1.0.5).
python3-bme680 is already the newest version (1.0.5).
Requirement already satisfied: rpi-ws281x in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: rpi-ws281x in /usr/local/lib/python3.5/dist-packages
Requirement already satisfied: smbus2 in /usr/local/lib/python2.7/dist-packages
Requirement already satisfied: smbus2 in /usr/local/lib/python3.5/dist-packages
Collecting rpi-vl53l0x
Using cached <LINK_TEXT text=“https://files.pythonhosted.org/packages … 0.2.tar.gz”>https://files.pythonhosted.org/packages/7c/f6/13af61a4bbe0dac49ecb22667a61fc341e1768deb4aaf7398a590dd5df10/rpi_vl53l0x-0.0.2.tar.gz</LINK_TEXT>
Building wheels for collected packages: rpi-vl53l0x
Running setup.py bdist_wheel for rpi-vl53l0x … error
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-EEgelO/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmp9NnoqZpip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_py
Compiling vl53l0x library…
make: *** No targets specified and no makefile found.  Stop.
creating build
creating build/lib.linux-armv6l-2.7
copying vl53l0x_api.py -> build/lib.linux-armv6l-2.7
copying ez_setup.py -> build/lib.linux-armv6l-2.7
running build_ext
building ‘_rpi_vl53l0x’ extension
swigging rpi_vl53l0x.i to rpi_vl53l0x_wrap.c
swig -python -o rpi_vl53l0x_wrap.c rpi_vl53l0x.i
rpi_vl53l0x.i:25: Error: Unable to find ‘…/VL53L0X_1.0.2/Api/core/inc/vl53l0x_api.h’
rpi_vl53l0x.i:26: Error: Unable to find ‘…/VL53L0X_1.0.2/Api/core/inc/vl53l0x_def.h’
rpi_vl53l0x.i:27: Error: Unable to find ‘…/platform/inc/vl53l0x_platform.h’
error: command ‘swig’ failed with exit status 1
Failed building wheel for rpi-vl53l0x
Running setup.py clean for rpi-vl53l0x
Failed to build rpi-vl53l0x
Installing collected packages: rpi-vl53l0x
Running setup.py install for rpi-vl53l0x … error
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-EEgelO/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-lCnKfM-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running build_ext
Command “/usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-EEgelO/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-lCnKfM-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-EEgelO/rpi-vl53l0x/
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-i4rVht/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmpOoiwGcpip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_py
creating build
running build_ext
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-i4rVht/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-T3Mpi2-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running build_ext
Command “/usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-i4rVht/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-T3Mpi2-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-i4rVht/rpi-vl53l0x/
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-FyFym6/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” bdist_wheel -d /tmp/tmpqXQNG7pip-wheel- --python-tag cp27:
running bdist_wheel
running build
running build_py
creating build
running build_ext
Complete output from command /usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-FyFym6/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-UMRmCG-record/install-record.txt --single-version-externally-managed --compile:
running install
running build
running build_py
creating build
running build_ext
Command “/usr/bin/python -u -c “import setuptools, tokenize;file=’/tmp/pip-build-FyFym6/rpi-vl53l0x/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-UMRmCG-record/install-record.txt --single-version-externally-managed --compile” failed with error code 1 in /tmp/pip-build-FyFym6/rpi-vl53l0x/
Grove.py installation FAILED, FAILED, FAILED
I might have a solution. Looks like it cannot find whatever it needs of ‘…/VL53L0X_1.0.2’.
I ended up going to the actual groove.py git page (https://github.com/Seeed-Studio/grove.py) and follow the developers steps instead of the ‘Online install’. Installed all the dependencies for python 3.
Eventually if the problem persists you can also go and get the ‘VL53L0X_rasp_python’ yourself manually at https://github.com/johnbryanmoore/VL53L0X_rasp_python, follow the install steps and make sure the folder is 1 folder above your ‘groove.py’ folder with the name ‘VL53L0X_1.0.2’.
Thank you for your response.
I will try this right away.
I redid and actually all I needed to make it work was following the instructions of groove.py’s git page (https://github.com/Seeed-Studio/grove.py). Only had to make sure pip for python 2 was installed.
Oddly enough, I am still stuck with another issue. I have a Grove Base Hat for Raspberry Pi Zero and if I use it with a Pi Zero Wireless I have a return message stating Illegal Instruction. If I use the very same SD card on a Pi 3 B+ it works fine… Opening another thread for this, once it’s approved I’ll add a link.
