Grove - AHT20 I2C Temperature and Humidity Sensor
Hi!
Does anyone know when will be python code/library avaiable for Grove - AHT20 I2C Industrial Grade Temperature and Humidity Sensor ?
Is eventually anyone succeeded to use it with pyton?
Hi @vidist
The general grove.py library for Seeedstudio Grove Devices includes a module for the AHT20.
It worked quite well for me:
Just be aware that if you use the sensor with a recent version of the reTerminal, the I2C address of the AHT20 (0x38) will collide with the address of the built-in I/O expander. You will need to create a new I2C bus and map it to an available GPIO. This Instructable by JJ Slabbert might help:
Thanks I will try it!
