A handy tip that may suit your situation: You can take a 16 pin socket and remove 2 of the sockets with a razor blade or sharp knife. First cut away the minimum amount of material to get rid of the extra pins. Then whittle away the extra plastic bit by bit. Finally, tidy up with some sandpaper. Buy a few extra sockets to practice on.
I am new to Seeed products and currently designing and buying parts for a project that will include a Xiao ESP32S3.
This is a related question regarding the 7-pin male header that gets soldered to the Xiao board. I am particularly interested in the header-pin cross-section and the thru-holes on the Xiao ESP32S3 card. I have not yet purchased my Xiao so I do not have a way (at the moment) to verify a concern. The concern is that a standard off-the-shelf 2.54 mm pitch breakaway header will not insert into the thru-holes in the Xiao.
A standard off-the-shelf breakaway pin header with 2.54 mm pin pitch uses square cross-section pins where the square is 0.64 x 0.64 mm. This square dimension needs to fit through the diameter of the circular thru-hole on the Xiao card. The hole diameter needs to be able to accommodate the maximum dimension of the pin cross-section which is nominally 0.64 * (2)^0.5 = 0.91 mm. That means that the hole diameter in the Xiao card needs to be AT LEAST 0.91 mm in order for the pins to fit through in order to solder the header to the card.
But… the two independent 3D models of the Xiao ESP32S3 that I have grabbed off the internet both have the diameter of those thru-holes in the card as 0.75 mm. If the models are accurate, then those holes are too small for a standard off-the-shelf breakaway header with square pins. I realize that both 3D models that I have grabbed off the internet (one from Digikey, the other from a 3D model repository) could be in error on the thru-hole diameter. However, there are photographs on the internet of the Xiao that I have grabbed and pasted into Photoshop to make rough measurements of the hole diameters… and those measurements also indicate that those thru-holes have small diameters. As a point of reference, it is typical to have a thru-hole diameter in a PCB of 1.02 mm to accomodate 0.64 x 0.64 mm square cross-section pins.
Can somebody confirm for me that the thru-holes in the Xiao board will accommodate standard 0.64 x 0.64 mm square pins or not? Do I need to purchase some kind of non-standard 7-pin header to solder to the Xiao? Thanks!
… pretty sure they are standard pins…
Thanks for raising this, Ecclectic — it is a useful check before ordering. In practice, the standard 0.64 mm square pins supplied with the XIAO boards do fit the plated holes, even though the nominal hole size in the model looks tight. The holes are made for those pins to pass through for soldering, so a light push should seat them without forcing. I would try one header on its own first, check that it sits flat and square, and only then solder the rest. If a pin feels very tight, check for a bent pin or a small solder splash in the hole rather than enlarging the hole.
Thanks all for the confirmation that 0.64 mm square pins will fit through the holes in the Xiao board. It seems that both of the independent 3D models that I acquired from the interweb are inaccurate in the same way with 0.75 mm thru-holes that clearly wouldn’t work for a 0.64 mm square pin. I just wanted to make sure I didn’t need to buy some kind of non-standard special male pin header for the Xiao. I searched Digikey, Newark, etc. in vain for a couple of hours trying to find a 2.54 mm pitch male pin header with anything smaller than a 0.64 mm square pin. If they exist they are harder to find than 2 hrs. of searching would produce.
I’m a retired mechanical engineer; I understand and can handle the mechanical problem of a square peg in a round hole… but I’m lacking in electrical PCB/components design knowledge.
Thanks for helping out this newbie!
