Hi, i’m working on an IoT project that using seeedstudio lora lorawan gateways 915mhz for raspberry pi-3 and follow the steps to configure the board.
(http://wiki.seeedstudio.com/LoRa_LoRaWan_Gateway_Kit/).
I get stuck at step 4 Use Seeeduino LoRaWAN GPS(RHF76-052AM) access LoRaWAN server, section d where failed to display expected output in my serial monitor as compared to the tutorial. What I get is an error, “+MODE: ERROR(-1)”.
I hope someone can give me some insight on how to solve this error.
Thank you.
I am stuck at the same step. Connecting the board to the pc does not induce any addition of a com port.
Did you solve your issue?
