Error while installing/moving jetpack 4.6.1 to sd card on Seedstudio J101 nvidia jetson nano
I have a SeedStudio J101 carrier board jetson nano 4 gb dev kit with jetpack 4.6.1 in it. Problem is the OS is installed in it’s internal memory(16gb emmc) and less space is available around 1gb to do any projects. So I wanted to use sd card for the same. I have enabled the SD card proper format and while trying to move the OS to the SD card so that I can boot from the sd card, I followed the series of commands from the official doc here:- J1010 Boot From SD Card - Seeed Wiki
I get error after Error after performing the foll:-
./copyRootToUSB.sh -p /dev/mmcblk1p1
The error is as follows:-
nvidia@ubuntu:~/bootFromUSB$ ./copyRootToUSB.sh -p /dev/mmcblk1p1
Device Path: /dev/mmcblk1p1
Target: /media/nvidia/mvnvidia
[sudo] password for nvidia:
Hit:1 https://repo.download.nvidia.com/jetson/common r32.7 InRelease
Hit:2 http://ports.ubuntu.com/ubuntu-ports bionic InRelease
Hit:3 https://repo.download.nvidia.com/jetson/t210 r32.7 InRelease
Get:4 http://ports.ubuntu.com/ubuntu-ports bionic-updates InRelease [88.7 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports bionic-backports InRelease [83.3 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports bionic-security InRelease [88.7 kB]
Get:7 http://ports.ubuntu.com/ubuntu-ports bionic-updates/main arm64 DEP-11 Metadata [291 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports bionic-updates/universe arm64 DEP-11 Metadata [297 kB]
Get:9 http://ports.ubuntu.com/ubuntu-ports bionic-backports/main arm64 DEP-11 Metadata [8,092 B]
Get:10 http://ports.ubuntu.com/ubuntu-ports bionic-backports/universe arm64 DEP-11 Metadata [10.1 kB]
Get:11 http://ports.ubuntu.com/ubuntu-ports bionic-security/main arm64 DEP-11 Metadata [49.1 kB]
Get:12 http://ports.ubuntu.com/ubuntu-ports bionic-security/universe arm64 DEP-11 Metadata [56.0 kB]
Fetched 972 kB in 3s (352 kB/s)
Reading package lists... Done
Building dependency tree
Reading state information... Done
rsync is already the newest version (3.1.2-2.1ubuntu1.5).
The following packages were automatically installed and are no longer required:
  apt-clone archdetect-deb bogl-bterm busybox-static cryptsetup-bin dpkg-repack gir1.2-timezonemap-1.0 gir1.2-xkl-1.0 grub-common
  kde-window-manager kinit kio kpackagetool5 kwayland-data kwin-common kwin-data kwin-x11 libdebian-installer4 libkdecorations2-5v5
  libkdecorations2private5v5 libkf5activities5 libkf5attica5 libkf5completion-data libkf5completion5 libkf5declarative-data
  libkf5declarative5 libkf5doctools5 libkf5globalaccel-data libkf5globalaccel5 libkf5globalaccelprivate5 libkf5idletime5
  libkf5jobwidgets-data libkf5jobwidgets5 libkf5kcmutils-data libkf5kcmutils5 libkf5kiocore5 libkf5kiontlm5 libkf5kiowidgets5
  libkf5newstuff-data libkf5newstuff5 libkf5newstuffcore5 libkf5package-data libkf5package5 libkf5plasma5 libkf5quickaddons5
  libkf5solid5 libkf5solid5-data libkf5sonnet5-data libkf5sonnetcore5 libkf5sonnetui5 libkf5textwidgets-data libkf5textwidgets5
  libkf5waylandclient5 libkf5waylandserver5 libkf5xmlgui-bin libkf5xmlgui-data libkf5xmlgui5 libkscreenlocker5
  libkwin4-effect-builtins1 libkwineffects11 libkwinglutils11 libkwinxrenderutils11 libqgsttools-p1 libqt5designer5 libqt5help5
  libqt5multimedia5 libqt5multimedia5-plugins libqt5multimediaquick-p5 libqt5multimediawidgets5 libqt5opengl5 libqt5quickwidgets5
  libqt5sql5 libqt5test5 libxcb-composite0 libxcb-cursor0 libxcb-damage0 os-prober python3-dbus.mainloop.pyqt5 python3-icu
  python3-pam python3-pyqt5 python3-pyqt5.qtsvg python3-pyqt5.qtwebkit qml-module-org-kde-kquickcontrolsaddons
  qml-module-qtmultimedia qml-module-qtquick2 rdate tasksel tasksel-data
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 248 not upgraded.
 10,265,934,548  94%    2.27MB/s    1:11:49 (xfr#94253, ir-chk=1002/146692)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpiCC-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpiCC.openmpi-wrapper-data.txt" -> "mpiCC-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpic++.openmpi-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicc.openmpi-wrapper-data.txt" -> "mpicc-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicxx-wrapper-data.txt" -> "mpic++-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpicxx.openmpi-wrapper-data.txt" -> "mpicxx-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif77-wrapper-data.txt" -> "mpifort-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif77.openmpi-wrapper-data.txt" -> "mpif77-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif90-wrapper-data.txt" -> "mpifort-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/mpif90.openmpi-wrapper-data.txt" -> "mpif90-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/oshcc-wrapper-data.txt" -> "shmemcc-wrapper-data.txt" failed: Bad message (74)
rsync: symlink "/media/nvidia/mvnvidia/usr/share/openmpi/oshfort-wrapper-data.txt" -> "shmemfort-wrapper-data.txt" failed: Bad message (74)
rsync: recv_generator: mkdir "/media/nvidia/mvnvidia/usr/share/openmpi/amca-param-sets" failed: Bad message (74)
*** Skipping any contents from this failed directory ***
 10,297,136,537  94%    2.25MB/s    1:12:45 (xfr#95506, ir-chk=1000/148181)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-btl-vader.txt.vAMDSZ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-coll-sync.txt.FYeYyz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-dash-host.txt.3zgvng" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-errmgr-base.txt.1rT9r8" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ess-base.txt.NVQx07" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ess-hnp.txt.CjXlNz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-hostfile.txt.TlFO6i" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-base.txt.SKjXKt" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-bml-r2.txt.gEFh8G" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-coll-base.txt.SM59Sb" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-osc-base.txt.jVaYh7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mca-var.txt.B6ZLXc" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-api.txt.HtspiC" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-base.txt.5DP71j" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-openib-cpc-base.txt.Jy85ni" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-openib.txt.gNNfjv" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-sm.txt.rmVNvW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-btl-tcp.txt.gy4NwJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-coll-sm.txt.70JepG" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-common-sm.txt.eGFYFM" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-errors.txt.0hJioQ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-pml-ob1.txt.ykG2zX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpi-runtime.txt.uhSwVc" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mpool-base.txt.qCUPEw" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mtl-ofi.txt.kPo7LA" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-mtl-psm.txt.Ilvd4H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-base.txt.wHZ32X" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-tcp.txt.gtokSj" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oob-ud.txt.cnq67P" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-common-verbs.txt.eY6WQs" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-hwloc-base.txt.ga9QIN" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-runtime.txt.E12CQ9" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-mmap.txt.iBHxPA" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-posix.txt.gxcQg4" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-shmem-sysv.txt.wYCoSC" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-timer-linux.txt.g73Tbf" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-util.txt.4jC4IW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal-wrapper.txt.0SNWCE" failed: Bad message (74)
 10,297,256,055  94%    2.25MB/s    1:12:45 (xfr#95565, ir-chk=1012/148252)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-opal_info.txt.qFgoUl" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-clean.txt.Ok0Rh2" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-filem-raw.txt.cc42XI" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-info.txt.Ski3kt" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-odls-base.txt.4Buc2d" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-odls-default.txt.kfh9RX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-ps.txt.qP0L0H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-base.txt.aKq6ir" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-md.txt.mHU919" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-ppr.txt.W2C5MW" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-resilient.txt.oEdaXJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-rr.txt.gJyipw" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rmaps-seq.txt.6cZUii" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-rtc-base.txt.Qz3aw3" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-runtime.txt.SFenyS" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-server.txt.KOZxLH" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orte-top.txt.IUzoix" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orted.txt.sjB2Wl" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-orterun.txt.ss8wRa" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-info.txt.Yh5n0Y" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-memheap.txt.UUughM" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-spml-yoda.txt.Camt7C" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem-mmap.txt.I4Dkfu" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem-sysv.txt.y4SMSm" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-oshmem-sshmem.txt.qDtXVf" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-base.txt.i8Ba57" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-rsh.txt.al31v6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-plm-slurm.txt.MfDQt4" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-pmix-base.txt.caEPI3" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-base.txt.Qjrhd7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-gridengine.txt.w8Qk69" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-simulator.txt.CoK5Be" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-ras-slurm.txt.2C1Rmi" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rcache-base.txt.ySvjVo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-regex.txt.ebzRzz" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rmaps_rank_file.txt.wv9quJ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-rtc-freq.txt.7k7iHN" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-shmem-api.txt.OxFufR" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-shmem-runtime.txt.pb5zuX" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.help-state-staged-hnp.txt.8qon22" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mca-btl-openib-device-params.ini.tUgAN7" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpic++-wrapper-data.txt.SjeB8i" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpicc-wrapper-data.txt.bomgNu" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.mpifort-wrapper-data.txt.wReZ4H" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.opalc++-wrapper-data.txt.LBlEJU" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.opalcc-wrapper-data.txt.E6vkx6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.openmpi-valgrind.supp.zyOzIo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.ortecc-wrapper-data.txt.8SwbrH" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.shmemcc-wrapper-data.txt.1Hb8N1" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openmpi/.shmemfort-wrapper-data.txt.oWvPNs" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openssh/.sshd_config.Zn1gLZ" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/openssh/.sshd_config.md5sum.kZXX3J" failed: Bad message (74)
 10,394,651,244  94%    2.26MB/s    1:13:06 (xfr#101429, ir-chk=1085/155695)
rsync: recv_generator: mkdir "/media/nvidia/mvnvidia/usr/share/transmission/web" failed: Bad message (74)
 10,407,690,629  94%    2.26MB/s    1:13:10 (xfr#102535, ir-chk=1158/157066)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.controls.ui.x0GHYo" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.playlist.ui.OgJTY6" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.preferences.ui.r4Olr8" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.properties.ui.X91F4q" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.shortcuts.ui.pRxtFU" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.totem.ui.PnKjxE" failed: Bad message (74)
rsync: mkstemp "/media/nvidia/mvnvidia/usr/share/totem/.uri.ui.Pf9EEF" failed: Bad message (74)
 11,843,686,748  95%    2.13MB/s    1:28:12 (xfr#132968, to-chk=0/192726)
rsync error: some files/attrs were not transferred (see previous errors) (code 23) at main.c(1196) [sender=3.1.2]
Please help in resolving this issue.
There are a few possible reasons why you might be getting an error while installing/moving JetPack 4.6.1 to an SD card on a Seedstudio J101 Nvidia Jetson Nano. Here are some of the most common causes and how to fix them:
  • The SD card is not formatted correctly. The SD card must be formatted in FAT32 or exFAT format. You can use the SD Memory Card Formatter tool from the SD Association to format the SD card.
  • The SD card is not large enough. The minimum recommended size for the SD card is 16GB. If the SD card is too small, the JetPack installation will fail.
  • The SD card is corrupted. If the SD card is corrupted, the JetPack installation will fail. You can try formatting the SD card again or using a different SD card.
  • The JetPack image is corrupt. If the JetPack image is corrupt, the JetPack installation will fail. You can try downloading the JetPack image again or using a different JetPack image.
If you have tried all of the above and you are still getting an error, you can contact Nvidia support for help.
