ERROR - seeedstudio serial bluetooth module
I am using ssCom32 to program a seeedstudio bluetooth module. I followed the pdf file given in a other post that tells how to connect it. I am using a 3.3 volts power source, the Rx pin receive 2.5 v messages since I am usuing a voltage divider to drop the voltage from 5 to the requirements (1.8-3.6v). Nevertheless, whenever i start ssCom32, all i receive from the module is “ERROR” at least twice per second along with other status message. Here is an exemple:
ERROR
ERROR
+BTSTATE:3
ERROR
+BTSTATE
ERROR
WORK:MASTER
+BTSTATE:0
WORK:MASTER
ERROR
+BTSTATE
ERROR
WORK:M
ERROR
ERROR
ERROR
+BTSTATE
+BTSTATE
+BTSTATE
ERROR
ERROR
WORK:M
WORK:M
WORK:M
ERROR
ERROR
What does all these “ERROR” mean exactly??? I would like to fix it but no where in the datasheet or in the forum does it talk about problems like this
Up
