I am trying to install a temperature and humidity sensor to a Wio terminal. It uses the Seeed_Arduino_LCD library which I have download the zip for and included under Sketch>Include Library>Add zip library. But I am getting this error message:
FQBN: Seeeduino:samd:seeed_wio_terminal
Using board ‘seeed_wio_terminal’ from platform in folder: C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3
Using core ‘arduino’ from platform in folder: C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3
Detecting libraries used…
C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -D__SKETCH_NAME__=""“calibrate.ino”"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10607 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -DTXRXLED_ENABLE -DROLE=0 -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\variants\wio_terminal C:\Users\Lars Brandt\AppData\Local\Temp\arduino\sketches\CDAA6E5286839D065F50DB2450BCB815\sketch\calibrate.ino.cpp -o nul
Alternatives for TFT_eSPI.h: [Seeed_Arduino_LCD@1.6.0 Seeed_Arduino_LCD@1.6.0]
ResolveLibrary(TFT_eSPI.h)
→ candidates: [Seeed_Arduino_LCD@1.6.0 Seeed_Arduino_LCD@1.6.0]
C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -D__SKETCH_NAME__=""“calibrate.ino”"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10607 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -DTXRXLED_ENABLE -DROLE=0 -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\variants\wio_terminal -Ic:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD C:\Users\Lars Brandt\AppData\Local\Temp\arduino\sketches\CDAA6E5286839D065F50DB2450BCB815\sketch\calibrate.ino.cpp -o nul
Alternatives for SPI.h: [SPI@1.0]
ResolveLibrary(SPI.h)
→ candidates: [SPI@1.0]
C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -D__SKETCH_NAME__=""“calibrate.ino”"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10607 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -DTXRXLED_ENABLE -DROLE=0 -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\variants\wio_terminal -Ic:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\SPI C:\Users\Lars Brandt\AppData\Local\Temp\arduino\sketches\CDAA6E5286839D065F50DB2450BCB815\sketch\calibrate.ino.cpp -o nul
Alternatives for Adafruit_ZeroDMA.h: [Adafruit Zero DMA Library@1.0.4]
ResolveLibrary(Adafruit_ZeroDMA.h)
→ candidates: [Adafruit Zero DMA Library@1.0.4]
C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -D__SKETCH_NAME__=""“calibrate.ino”"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10607 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -DTXRXLED_ENABLE -DROLE=0 -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\variants\wio_terminal -Ic:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\SPI -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\Adafruit_ZeroDMA C:\Users\Lars Brandt\AppData\Local\Temp\arduino\sketches\CDAA6E5286839D065F50DB2450BCB815\sketch\calibrate.ino.cpp -o nul
Alternatives for DHT.h: [DHT sensor library@1.4.6 Grove Temperature And Humidity Sensor@2.0.1]
ResolveLibrary(DHT.h)
→ candidates: [DHT sensor library@1.4.6 Grove Temperature And Humidity Sensor@2.0.1]
C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\arm-none-eabi-gcc\7-2017q4/bin/arm-none-eabi-g++ -mcpu=cortex-m4 -mthumb -c -g -Os -w -std=gnu++14 -ffunction-sections -fdata-sections -fno-threadsafe-statics -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -D__SKETCH_NAME__=""“calibrate.ino”"" -w -x c++ -E -CC -DF_CPU=120000000L -DARDUINO=10607 -DARDUINO_WIO_TERMINAL -DARDUINO_ARCH_SAMD -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -DENABLE_CACHE -DTXRXLED_ENABLE -DROLE=0 -Os -DVARIANT_QSPI_BAUD_DEFAULT=50000000 -D__SAMD51P19A__ -DWIO_TERMINAL -DSEEED_WIO_TERMINAL -DSEEED_GROVE_UI_WIRELESS -D__SAMD51__ -DUSB_VID=0x2886 -DUSB_PID=0x802D -DUSBCON -DUSB_CONFIG_POWER=100 -DUSB_MANUFACTURER=“Seeed Studio” -DUSB_PRODUCT=“Seeed Wio Terminal” -DROLE=0 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino/TinyUSB/Adafruit_TinyUSB_ArduinoCore/tinyusb/src -D__FPU_PRESENT -DARM_MATH_CM4 -mfloat-abi=hard -mfpu=fpv4-sp-d16 -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/Core/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS\5.7.0/CMSIS/DSP/Include/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\tools\CMSIS-Atmel\1.2.1/CMSIS-Atmel/CMSIS/Device/ATMEL/ -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\cores\arduino -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\variants\wio_terminal -Ic:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\SPI -IC:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\Adafruit_ZeroDMA -Ic:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\DHT_sensor_library C:\Users\Lars Brandt\AppData\Local\Temp\arduino\sketches\CDAA6E5286839D065F50DB2450BCB815\sketch\calibrate.ino.cpp -o nul
C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\calibrate\calibrate.ino:4:10: fatal error: Seeed_Arduino_LCD.h: No such file or directory
#include <Seeed_Arduino_LCD.h>
compilation terminated.
Multiple libraries were found for “DHT.h”
Used: C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\DHT_sensor_library
Not used: C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Grove_Temperature_And_Humidity_Sensor
Multiple libraries were found for “TFT_eSPI.h”
Used: C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD
Not used: C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\Seeed_Arduino_LCD
Alternatives for Seeed_Arduino_LCD.h: []
ResolveLibrary(Seeed_Arduino_LCD.h)
→ candidates: []
Using library Seeed_Arduino_LCD at version 1.6.0 in folder: C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\Seeed_Arduino_LCD
Using library SPI at version 1.0 in folder: C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\SPI
Using library Adafruit Zero DMA Library at version 1.0.4 in folder: C:\Users\Lars Brandt\AppData\Local\Arduino15\packages\Seeeduino\hardware\samd\1.8.3\libraries\Adafruit_ZeroDMA
Using library DHT sensor library at version 1.4.6 in folder: C:\Users\Lars Brandt\Desktop\Arduinosketcheddesktop\libraries\DHT_sensor_library
exit status 1
Compilation error: Seeed_Arduino_LCD.h: No such file or directory
