Edge Impulse 唤醒词触发后,OPUS 音频流经常中断或解码失败
Fatal (internal) error in lib/arduino-libopus/src/opus-1.3.1/silk/NSQ_del_dec.c, line 584: assertion failed: psSampleState[ k ][ 0 ].RD_Q10 >= 0
abort() was called at PC 0x420274c3 on core 0
Backtrace: 0x40377592:0x3fcba7f0 0x4037d489:0x3fcba810 0x403837a5:0x3fcba830 0x420274c3:0x3fcba8b0 0x420274fd:0x3fcba8d0 0x4201c4e2:0x3fcbaa20 0x4201b7df:0x3fcbcf40 0x4200f916:0x3fcbd000 0x420101e1:0x3fcbd130 0x420043c4:0x3fcbd170 0x4200445b:0x3fcbd1a0
ELF file SHA256: 95b7c0de1b55ad73
Rebooting…
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0xc (RTC_SW_CPU_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x403771a0
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce3808,len:0x44c
load:0x403c9700,len:0xbd8
load:0x403cc700,len:0x2a80
entry 0x403c98d0
现在再在采用edge_impulse平台的语音唤醒的功能和OPUS格式传输实现的语音交互,为什么会一直出现下面的这个问题呢,我试了好久都没成功,问题到底在哪呢?
这个输出是环境问题,还是代码的问题
是库冲突了?还是代码格式有问题?
我采用的是XIOAesp32s3sense 作为开发板,板载麦克风录音,连接MAX98357播报,
我现在在edge impluse平台上只训练了两个类,
How to Fix It
  1. Verify Frame Size & Alignment: Ensure audio buffers fed to OPUS strictly match valid frame durations (10ms, 20ms, 40ms, or 60ms @ 16 kHz = 320, 640, 1280 samples). Never pass partial or unaligned I2S buffers to the encoder/decoder.
  2. Check Compiler Defines: Make sure -DFIXED_POINT=1 and -DOPUS_BUILD are set in build flags (build_flags in PlatformIO or cflags in Arduino IDE) to prevent Q10 fixed-point overflows.
  3. Isolate Cores: Pin the Edge Impulse inferencing task to Core 1 and keep I2S audio capture / OPUS streaming on Core 0 (or vice versa) with a thread-safe FreeRTOS Queue to prevent frame corruption during wake-word detection.
Diagnosis
It’s a libopus internal library/configuration bug combined with buffer corruption / invalid payload state.
Here is what the crash log reveals:
1. What the Assertion Error Means
The crash happens deep inside the Opus encoder/decoder’s SILK narrowband codec loop: Fatal (internal) error in lib/arduino-libopus/src/opus-1.3.1/silk/NSQ_del_dec.c, line 584: assertion failed: psSampleState[ k ][ 0 ].RD_Q10 >= 0
  • NSQ_del_dec.c is the Noise Shaping Quantization (Delayed Decision) module in the SILK layer.
  • RD_Q10 tracks Rate-Distortion cost during audio quantization.
  • Under normal conditions, rate-distortion cost is strictly positive. The assertion triggers because RD_Q10 wrapped around or went negative (< 0) due to integer overflow / fixed-point scaling failure or corrupted input audio frames being fed to the encoder.
2. The Core Causes
A. Feeding Invalid/Corrupted Audio Packets to opus_decode()
  • The user triggers an Edge Impulse wake-word inference loop, then immediately passes audio streams through OPUS.
  • If I2S buffer reads overlap with Edge Impulse running inference on CPU Core 0, missing bytes or misaligned frame sizes (e.g., passing 10ms of audio when the decoder expects 20ms frame sizes) cause SILK’s internal state machine to calculate invalid floating/fixed-point metrics, hitting the assert().
B. Floating-Point vs. Fixed-Point Configuration Conflict
  • arduino-libopus 1.3.1 can be compiled in FIXED_POINT (integer) or FLOATING_POINT mode.
  • On the ESP32-S3 (Xtensa LX7 with FPU), compiling libopus without -DFIXED_POINT or using mismatching Q-format definitions in config.h causes internal SILK state variables (RD_Q10) to overflow.
C. Core 0 Stack/Memory Contention with Edge Impulse
  • The crash shows abort() was called at PC 0x420274c3 on core 0.
  • Edge Impulse models on the XIAO ESP32-S3 Sense often run inference on Core 0 or tie up PSRAM. If I2S audio capture drops frames or overwrites the OPUS input stream during model evaluation, the decoder gets bad frame headers.
