Corrosion free soil moisture sensor
Does SeedStudio have a corrosion-proof soil moisture sensor? I used the Grove soil moisture sensor earlier, but it got corroded after one or two days.
So, which one did you try, They have this one, to and a more expensive version also
or this one, both claim corrasion resistant. YMMV
I used this one earlier Grove - Moisture Sensor | Seeed Studio Wiki
Got it from techshopbd years ago.
Yea, they work but NOT corrosion resistant, in HIGH EC enviro’s the drift as it corrodes is significant. Proper wet & dry periods or cycles is key to the longevity of them.
i think the device you linked uses the capacitive effect, but the circuit should probably epoxy in! IMO
Thank you for choosing Seeed products.
What is the application scenario for your sensor?
What is your budget for purchasing sensors?
If you want corrosion resistance, we recommend purchasing a Sensecap sensor.
This is the link to the bazaar, where you can choose and purchase the sensors you want.
Best Regards!
