Connect Grove BMP280 to PC
Hi all,
I am looking for a cheap way to add a barometer and thermometer inside my pc-case. But I have no clue how to do that. I looked around for a while and found the Grove BMP280. I looked around some, but it’s not worth spending hours, if I might not even be able to use it…
Can I connect the Grove BMP280 to my pc directly and use it via Windows? (FYI: I have a MSI MEG x570 Unify motherboard) Can I connect the Grove BMP280 to my pc indirectly, via USB or something other, and use it via Windows? (preferably below 50 dollars or Euros)
If this is not possible, do you know a product that could do this? The point is to measure over- or underpressure in the case.
Thank you in advance…
Bar.
ONLY $18.8
That is fantastic! Thank you. I’m going to start reading the documentation now… :wink:
