I replaced the TFT_eSPI library from Bodmer with one frrom Maxwelltoo and changed the User_Setup_Select.h file, but the examples fail to compile. They will compile with the Bodmer library, but the display does not work properly - I presume because there is no setup file for the Round Display.
I am using a Xiao ESP32S3 Sense with the display.
Is the error message for compilation available? This will enable us to help you determine what the problem is as soon as possible.
When the program failed to compile, I saw warnings but did not see the error that caused it to fail.
Not sure what changed but the program now compiles. The warnings are the same. I can’t execute the program because of the SD card failure, so I can’t tell if the TOUCH_CS pin warning would cause a problem.
C:\Users\ralph\OneDrive\Documents\Arduino\libraries\TFT_eSPI-master/TFT_eSPI.h:970:8: warning: #warning >>>>------>> TOUCH_CS pin not defined, TFT_eSPI touch functions will not be available! [-Wcpp]
C:\Users\ralph\OneDrive\Documents\Arduino\Xiao_ESP32S3_round_display_take_picture\Xiao_ESP32S3_round_display_take_picture.ino: In function ‘void setup()’:
C:\Users\ralph\OneDrive\Documents\Arduino\Xiao_ESP32S3_round_display_take_picture\Xiao_ESP32S3_round_display_take_picture.ino:73:10: warning: ‘camera_config_t::::pin_sscb_sda’ is deprecated: please use pin_sccb_sda instead [-Wdeprecated-declarations]
config.pin_sscb_sda = SIOD_GPIO_NUM;
In file included from C:\Users\ralph\OneDrive\Documents\Arduino\Xiao_ESP32S3_round_display_take_picture\Xiao_ESP32S3_round_display_take_picture.ino:4:
C:\Users\ralph\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9/tools/sdk/esp32s3/include/esp32-camera/driver/include/esp_camera.h:117:87: note: declared here
int pin_sscb_sda attribute((deprecated(“please use pin_sccb_sda instead”))); /*!< GPIO pin for camera SDA line (legacy name) /
int pin_sscb_sda attribute((deprecated(“please use pin_sccb_sda instead”))); /!< GPIO pin for camera SDA line (legacy name) /
C:\Users\ralph\OneDrive\Documents\Arduino\Xiao_ESP32S3_round_display_take_picture\Xiao_ESP32S3_round_display_take_picture.ino:74:10: warning: ‘camera_config_t::::pin_sscb_scl’ is deprecated: please use pin_sccb_scl instead [-Wdeprecated-declarations]
config.pin_sscb_scl = SIOC_GPIO_NUM;
C:\Users\ralph\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.9/tools/sdk/esp32s3/include/esp32-camera/driver/include/esp_camera.h:121:87: note: declared here
int pin_sscb_scl attribute((deprecated(“please use pin_sccb_scl instead”))); /!< GPIO pin for camera SCL line (legacy name) /
int pin_sscb_scl attribute((deprecated(“please use pin_sccb_scl instead”))); /!< GPIO pin for camera SCL line (legacy name) */
Program warnings can be ignored and this will not affect the normal operation of the device.
